Question about HP LaserJet M3035 MFP Printer
Tell me exact steps of how to use scanner on hp laserjet m3035xs mfp
  • HP Master
  • 365 Answers
Read the manual.
If you do not have one download from the HP wwebsite
Posted on Feb 13, 2014
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
  • 1382 Answers
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
Posted on May 18, 2010
seeker5211
  • 1089 Answers
SOURCE: scanner error 6 in hp laserjet m1120 mfp
Cable may not be connected correctly, try reconnecting the scanner cable. Or the scanning software is corrupted. Try uninstalling and reinstalling the software. Did your scanner ever work?
Posted on May 27, 2010
  • 8 Answers
SOURCE: ERROR SCANNER 22 EN IMPRESORA
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Posted on Dec 02, 2010
How do i fix phone not personalized
If you want to change the fax header, run the fax setup wizard which is found from the control panel in "administration" tab and then fax setup.
Sep 24, 2014 | HP Hewlett Packard Laserjet M3035xs...
Says "scanner initializing". Have to reboot to clear.
scanner is unable to reach home position within allocated time.
you need to remove the glass platten and OIL the rails/drive shaft clearing any dust / rubbish as you go also clean the underside of the glass while its out. If this doesnt clear it then you will need a new scanner driver PCB/scanner motor ( replaced as 1 item)
Jan 10, 2014 | HP LaserJet M3035xs MFP All-In-One Printer
Installation
try the following link.
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/setupInstallResults/?cc=us&lang=en&sp4ts.oid=2512333&ac.admitted=1381904517780.876444892.199480143
Oct 13, 2013 | HP LaserJet M3035xs MFP All-In-One Printer
49.4C06 error
Getting code: 49.4C06 - ERROR. states to turn off HP LaserJet M3035xs MFp and turn back on to clear. We turned printer off and back on several times and still getting error code?
Feb 24, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
Scanner of m3035xs mfp not worked
You have to configure the digital sending option, if coping is happening..through wording we cannot express to configure, on line chat is the best method due to permissions required to configure..
Sep 13, 2011 | HP LaserJet M3035 MFP Printer
How to scan to computer using hp laserjet m3035xs mfp connect using a USB CABLE
install the scanner software on your cd hp and then in Word go "insert+image+scanner"
Jun 22, 2011 | HP LaserJet M3035 MFP Printer
Printer hp m3035xs giving this error"download file
The only, and easiest way I have found to solve this is to replace the formatter PCA.
Dec 16, 2010 | HP LaserJet M3035xs MFP All-In-One Printer
My printer m3035xs mfp only show this ?
I just fixed one of these and the problem appears to have been a failed formatter. The customers unit was not doing this all the time so I will not know for sure for a couple of weeks.
Sep 17, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
Have a client with 2 locations and in both locations the m3035xs mfp devices are constantly having communication errors between themselves and other recipients. The problem is primarily sending not...
Your machines are probably timing out waiting for space on the network
Some software is hyper critical when it comes to handshaking and stalls if its criteria is not met
We now test machines to the C drive of a host computer proving that it will up and down load and then tell the network guys to sort out their comms problems
Harsh but effective
Jul 04, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
Hp-ux print queue on a m305 mfp printer
Unplug the power cord for 10 seconds, or scroll through the menus for RESETS
Jan 05, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
HP LaserJet M3035 MFP Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
