Hotpoint wf320p washing machine leak
I pushed my washing machine back a bit as it had moved outwards because of the vibrations. I later noticed that there was water all over the floor. I pulled out the washing machine and checked the pipes but no obvious leaks. Then removed the bottom panel at the rear and the inside is wet and this can be see up the casing of the machine also towards the top. Not sure if the water has squirted up from the bottom or down for perhaps the detergent tray. Any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Pull the plug
check the pipes from the soap dish to the tub
Posted on Feb 09, 2014
4 Suggested Answers
  • 183 Answers
SOURCE: water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Posted on Dec 25, 2007
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
aasc
  • 1606 Answers
SOURCE: water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Posted on Aug 02, 2010
Testimonial: "I wish I had asked the question hours ago! Thanks."
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Washing machine will not turn on
First, check to be sure the door lock is securely fastened and the door is locking. Post back the results.
Jan 20, 2013 | Whirlpool WTW58ESVW Top Load Washer
My hotpoint washing machine is filling up in the drum, then 10 seconds later water is all over the floor. I have had the top and back off and checked the filter but can't work out where it's coming...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jul 05, 2011 | Hotpoint Washing Machines
How do i lift the top of the washing machine up to get at stuff that got caught during a spin cycle?
ther are 2 push clip under top panel 1 on each corner push clip in pull front panel outward 1 side at a time pull forward and lift up and off
Feb 04, 2010 | Hotpoint Washing Machines
My brandt washing machine(model wtc0633) vibrate seriously
Hi Steven. You maching is a top load type and it sounds like the leveling legs under you machine are no longer adjust properly. This can occur from moving the unit or just over time from normal use. You can verify this by pressing down individually (one at a time) on the 4 corners of the top of you unit. If it rocks when you press down or push on the the corners then your leveling legs are out of adjustment. Adjust the legs under the unit until it no longer moves when you press on the corners and see if this solves your problem. If you need more help later then reply to this post.
Jan 09, 2010 | Washing Machines
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lifter broken on Hotpoint BHWM129 - replacement on order but need to get the old one out Hotpoint says its easy to do but I am stuck - its a twelve hole lifter and I cant find out how to release the...
Grasp it firmly with both hands, and pull it towards you, it requires quite a bit of effort to do this.
Fit new one by pushing it in and towards rear of drum until you feel it click into place..
Please rate my solution.
Thanks.
Jul 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Trying to fit new belt
loop round the motor first then up around the pulley, this will be tight so pull halfway round and hold it to the pulley while turning it, rather like refitting a bicycle chain. make sure it runs cetrally on the pulley by adjusting it on the motor shafts grooves.
Aug 27, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarious 1000 de luxe
You need to check the lateral movement of the drum if it moves by more than 1-2 mm then the bearings need to be replaced.
Apr 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
