Question about Dell Inspiron 8500 Notebook
When I turn on my Dell Insiron 8500 laptop I get a black screen with a white flashing curser in the top left hand corner, or sometimes a grey striped screen...
I have tried pressing f2, f12, f8, ctl alt+delete, removing the battery and using an external monitor and nothing works. It sounds as though it could be starting up and I can hear the fan. Previous to this there were times that it would freeze and turn its self off... Is there any way you could help me restore my laptop, my important documents and sentimental data??? Please tell me this can be resolved!
  • Dell Master
  • 1,087 Answers
There should be a button on the keyboard, usually with a bad diagram of a monitor on it, along with something like an "FN" button, that allows you to switch between the LCD, External, and Both. Once in a while video drivers get a little flakey, and you have to use this to get your screen back.
There might be something in BIOS as well. Your user manual should describe this
Posted on Feb 09, 2014
    Guru:
  • 452 Answers
About your data, you can restore them, and about the laptop, try to remove the memory modules and clean it, then reinstall the memory and power up the laptop;
here you can learn how to remove the memory module:
When I turn on my Dell Insiron 8500 laptop I get a - 1b06dd22-752d-4de4-9995-eaa93f17902e.jpg
  • 3278 Answers
SOURCE: My Dell Inspiron 1520 will not load
Hello, Beth.
The most common reason is memory. Try reseating (remove and reinsert) the memory, first.
Power off the computer and disconnect all cables. Flip the laptop to the back. Remove the battery. The memory cover has 8 screws. Remove the memory modules at a 25 degree angle and reinsert them by pushing them down firmly by the ends.
If reseating the memory doesn't solve your problem, one module may be bad. So, remove and test each module one at a time.
Hope this helps.
Posted on Nov 23, 2009
  • 162 Answers
SOURCE: A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Posted on Jul 04, 2010
  • 3940 Answers
SOURCE: wont load windows got a
Most likely a hard drive issue. Might have a corrupt boot sector, might be a failing hard drive. Remove HDD and see if you can boot to a windows CD, if you can then the issue is with the drive.
Posted on Oct 09, 2010
  • 24 Answers
SOURCE: Dell Inspiron 1564 laptop with
when did you install windows 7? Windows 7 might be to strong for your laptop or you might have to reinstall windows 7.
Posted on May 26, 2011
SOURCE: My dell inspiron mini 10
I HAD HE SAME PROBLEM
IT SEEMS YOUR HARD DRIVE IS DEAD
NOW ORDER A NEW SATA HARD DRIVE AND REINSTALL THE WINDOW
IT WORKS
Posted on Jul 21, 2011
Hi i have a dell inspiron1545 and when i turn it on i get the dell screen then it just goes black with a flashing curser in the left hand corner i rang dell but its out of warrenty but they did say it...
Hello
It seems the Hard drive error but first you check hard drive in CMOS Setup, if the HD is appearing in Setup thats mean that the Hard Drive is OK
Then you have to try recover the system by installing Operating System with Recovery CD if you have or by any windows CD/DVD you may have.
Hope this helps, if so do rate the solution Good Luck
Jan 05, 2011 | Dell Inspiron 1545 Notebook
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
Hi I cannot download or open progeams with my laptop. Every time that I try to do it a balck screen pops up with a white flashing line on the left hand corner of the screen. I am operating on safe mode due...
You can press Control-F11 when you see the 'Dell' logo after you turn the computer on. If this doesn't work right off the bat, hold control while turning the machine on and keep tapping F11 until you see it begin to boot. If you haven't deleted the restore partition in your attempt to reinstall XP, you should be able to restore the system to factory spec by doing this. You will lose any data you have obviously, but the malware will be gone as well.
Oct 05, 2009 | Dell Inspiron 6000 Notebook
Hi I have a problem with my laptop insperion 6000.I cannot downlaod or open programs with my laptop. Evrytime that i try to do it a black screen pops up with a white flashing line on the left hand corner...
Go to Major Geeks.com and ask them how to get rid of the virus. They are a very good source of up to the minute virus fixes.
You cannot keep operating in safe mode. You must fix it.
Oct 01, 2009 | Dell Inspiron 6000 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
