Question about Cyberhome CH-DVD 300 DVD Player
Dvd stud can not open
DVD disk stud and the door cannot open
    Problem Solver:
  • 9 Answers
This happened to my computer,so I took a small flat headedvscrew driver and after lifting the flap I gingerly put the screw driver into the edge and with a lil tug it pulled right out, one prob is you may have is damping disk inside you need to get under it,sometimes there is a lil hole and insert the end of a paperclip and pop it opens only way I know other then taking the case apart you'd gain access that way unplugged doing any ofvthese
Posted on Feb 24, 2014
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Lg mini home theatre model FB 162 dvd door will not open dvd's will not play will not play
look for a tiny hole in the dvd door; insert a straightened paperclip into the hole; push in; the door will open then clean the laser lens with a dvd cleaning disk by running the disk in the machine
Feb 18, 2013 | Audio Players & Recorders
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
Disney D7500PDD Portable DVD Player doesnt spin DVD
Very Good Daniel,
if you are good with a srewdriver.. you could use a DVD from a computer and swap it to disney
Does the door to DVD slides out or pop the lid.
You still can swap if you are careful and you know what you are doing
I've done a few times.
Let me know in the future, if you can't, you can send to me for repair
Jul 25, 2010 | Disney D7500PDD Portable DVD Player
DOOR WILL NOT OPEN
You can usually open a disk player door by using a straightened paper clip. There is a small hole on the face of the disk face. Push the paper clip in, it should release the door. This may fix the jam.
Dec 29, 2009 | iLO DVDR04
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
The disk door couldnot open
On the front of most DVD players there is a button with EJECT printed under it.
The same button is normally on remotes.
Try pressing this button.
May 04, 2009 | Televison & Video
Samsung DVD-VR330: Disk Tray won't open
The solution is to unplug the machine and wait 10 secs. and plug it in again. I have to do this often. another part of the problem may be that some of the blank disks are bad. I got the DVD+R at Staples and about 4 out of 10 were able to be formatted. I am about to try the DVD-RWs.
Feb 01, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
14 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
