Question about Yamaha Audio Players & Recorders
Connection of a subwoofer to yamaha rx v480 receiver
How to connect a yamaha subwoofer to a yamaha receiver with no dedicated output for sub
    New Friend:
  • 62 Answers
Get an output from the receiver pass it through a crossover and you will get a low frequency signal , plug in into the sub..there you go.
Posted on Feb 11, 2014
  • 277 Answers
SOURCE: Connecting subwoofer to receiver.
have u checked that the sub option on the reciver is on?
Posted on Jan 31, 2006
ttech
  • 139 Answers
SOURCE: connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Posted on Jul 20, 2007
tech48
  • 624 Answers
SOURCE: Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Posted on Feb 06, 2009
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
How to hook up subwoofer for yamaha RX-496 2channels receiver
You need to connect the subwoofer to your receiver using the speaker wire connections on the rear of the receiver. Take the speaker input from the subwoofer to the A or B speaker terminals on the rear of the AV receiver. Then take the speaker outputs from the sub and connect to the main speaker terminals. Really you need to buy a receiver with a sub out to do it properly. Sell this one and buy another.
Mar 02, 2017 | Yamaha Audio Players & Recorders
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Subwoofer output issue 5.1 setup. 2 speakers
Try turning up the sub out-put, in the Receiver settings
Sep 11, 2013 | Yamaha RX-V757 Receiver
I have already purchased a yamaha receiver rx-v667 7.2 channels and I am looking for a subwoofer. Before purchasing the subwoofer I would like to understand how many connection options I already have: LFE?...
The 667 has two line level outputs to feed a subwoofer. They are identical. You only need one for most sub woofers. You need a suitable length pin audio (RCA) audio cable to connect.
Feb 17, 2011 | Yamaha RXV667 Receiver
I connected a non-powered subwoofer, but it is not responding. I have got bose speaker system accoustimas 10. romy13111958@gmail.com
hi,
u can connect the bose to ur receiver. connect all speaker output of or receiver to bose corresponding input. and the sub line to sub pre out. for any further assistance can contact through fixya.
ok
Dec 22, 2010 | Yamaha RX-V740 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Mar 31, 2009 | Yamaha RX-V363 Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Ccr1cd keeps turning off my yamaha receiver rx-v480 keeps turning off when i turn it on
check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
Dec 24, 2008 | Yamaha RX-V463 Receiver
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
277 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
