Question about Water Heaters
I need a thermastat for B57-O131-Y C1813 - Water Heaters
State electric 52 gallon duel element water heater. New lower element, new upper thermastat. Cycles and turns off. Water temp only gets to about 78 degrees at faucets.
power iso crack, power iso free, power iso free key, power iso full version, power iso serial, power iso software, poweriso crack, poweriso free, poweriso full version, poweriso key
Dec 19, 2017 | Water Water Heaters
How do I reset the safty system?
1) Copy following link:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) If this is Rheem-Richmond-Ruud, then you need new TRD glass vial.
You may also need new gas control valve, EV sensor, and other parts.
3) Might be cheaper to buy 40 gallon gas water heater at Lowes for $385, set 3-legged heater on bricks for ez access to arrestor screen, avoid dusty locations, provide more fresh air to unit, and perform required maintenance such as inspecting/cleaning air intake screen with compressed air.
Feb 24, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Changed shorted out bottom electric element and lower thermostat still no voltage to lower upper element reads 417 volts can upper thermostat effect lower thermastat?
Open following link to troubleshoot cause of problem:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Oct 06, 2010 | RELIANCE ELECTRIC WATER HEATER
No heat from water heater, wish to replace thermastat and heating elemnt, need part numbers please
thermostats and elements are fairly common items from home improvement stores. remove the old ones and take with you, a representitive can cross reference them for you. Just make sure the elements are of the same voltage and wattage rating
Aug 25, 2010 | Dayton Water Heaters
Need to relight Rheem hwh. Have not seen unit, but believe it is electric.
electric heaters dont need to be light because they dont use gas, the power is off to the heater or the thermastat is bad or the heating element is bad. call the manufacture and get free customer service and support over the phone.
Apr 27, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
6 yr old electric rheem fury 50 gallon all of a sudden runs out of hot water. Only one shower of hot water now where before atleast two.
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Mar 25, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
59 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
