Hello, You should be able to find the part you need through Panasonic which you can find here. Just type in your model number and a click the arrow and a list of parts will come up. The part you need is a spindle motor. The site also gives you a support contact number so you contact them either by phone or email. On average a spindle motor costs between 20-45 dollars depending on the model. If you plan on replacing the part yourself, I can tell you it is a difficult and time consuming job as you will have to take the laser assembly completely apart and you must be careful not to loose or damage any of the small springs and belts. Hope this helps and good luck
If you do not mind, could you please rate my help. I would greatly appreciate it. Thank you
Was this helpful?
Yes
No
Popular Solutions for Panasonic DMRES15 DVD Recorder
mi control remoto no funciona es grabador dvd panasonic dmr es16 de pronto no funciono estuve...
(More)
mi control remoto no funciona es grabador dvd panasonic dmr es16 de pronto no funciono estuve grabando una serie me puede plantear soluciones ,gracias,
This is on a DMR ES15 model. The remote used to work at one time. I tried unplugging the recorder...
(More)
This is on a DMR ES15 model. The remote used to work at one time. I tried unplugging the recorder for a while but it did not help. Is there a way to reset the unit back to factory specs? Could this be a problem with the remote itself? The unit will play a DVD if the play button is pushed on the unit itself but not via the remote.
