Question about Jenn-Air Cooktops
How to remove cooktop c221 c - Jenn-Air Cooktops
4 Suggested Answers
  • 1314 Answers
SOURCE: jenn-air cooktop
no i wouldnt long as its working
Posted on Mar 03, 2008
SOURCE: I need the drip pans ( one large & one small)
I was able to get the items at a local distrubitor. Thanks for your prompt response.
Posted on Jan 05, 2010
  • 7 Answers
SOURCE: I have a Jenn air
Here are the dimensions for the Jenn air c221 cooktop. Hoping this will help.
width 29 15/16th of an inch.
depth 21 9/16th of an inch.
cutout width is 28 7/8th of an inch.
cutout depth is 20 15/16th of an inch.
Posted on Feb 04, 2011
Uninstallation of Jenn-Air JED8430BDB cooktop
There are 2 clips under the cooktop, attached to the counter.
Remove the drawers under the cooktop to see the clips.
Jul 05, 2013 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I have a Jenn-Air CCE3401 Electric Cooktop I want to remove. How do I disconnect the wires from the cooktop? In other words, how do you get inside the cooktop to disconnect the wires? Disconnecting...
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Feb 12, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn air c221 cooktop in need of replacement what are the dimensions of this unit.
Feb 04, 2011 | Cooktops
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    How do I remove knobs for burners to clean them?
    To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
    Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
    GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
    Turn off the gas,unplug the power.
    Take the cooktop out of the cutout and support it on the countertop.
    Remove all grates and valve knobs.
    Remove all screws from the valves and the burners.
    Remove the burner base plates.
    You may have screw on the side holding the top to the base,if so,remove these too.
    The top will separate from the bottom exposing your parts.
    Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
    I need the drip pans ( one large & one small) for the burners on my jenn -air electric cooktop c221
    Jan 04, 2010 | Jenn-Air JEC9530 Electric Cooktop
    Jenn-air cooktop
    Mar 02, 2008 | Cooktops
    Remove ceramic cooktop
    grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
    Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
    Cooktops Logo
    71 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
