Question about Ario HC3269 32" LCD TV
Low volume remote control is at high volume but t.v sound is very low
Minimum volume way to high
There may be a low/high switch which lowers or raises the base sound level before the volume control has any effect.
Mar 11, 2015 | Coby CX-CD248 Radio/Cassette/CD Boombox
The volume on my acer aspire 6530 is to low although the control
if you have external speakers, try adjusting the volume there!
If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
Adjust the settings for device/s you use to hear sound.
Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
Low sound on harmony one
Is the remote set to adjust the volume on the TV? If it is going up all the way to 100% or Full on the TV then suggest checking the source. On some cable and satellite boxes they have a built-in volume control also. If that is set low, that would affect the amount of volume coming out of that device.
Mar 13, 2011 | Logitech Harmony One LCD Touchscreen...
How do i get the Audio to work?
  1. Check the volume control located on the front or side of your computer to be sure that it is not set at the lowest level. If the problem is not resolved, proceed to Step 2.
  2. Step 2 Right-click on the "Volume Control" icon located on the Start menu taskbar and then select "Open Volume Control."
  3. Step 3 Remove all checkmarks beside "Mute" in the Master Volume and all other visible categories. If the sound problem is not solved, proceed to Step 4.
  4. Step 4 Right-click on the "Volume Control" icon and select "Adjust Audio Properties."
  5. Step 5 Go to the Volume tab and adjust the "Device Volume" by moving the slider within the range from Low to High.
  6. Step 6 Click on "Speaker Volume" under Speaker Settings and move the slider within the range from Low to High to reset the left and right speaker volume. If the sound problem is not solved, proceed to Step 7.
  7. Step 7 Go to the Hardware tab and highlight the device with the sound issue and then click "Troubleshoot." Follow the prompts until the issue is resolved.
Mar 02, 2010 | Computers & Internet
Amplifier goes from low volume to high volume without touching any controls. I turn it down only to have it mysteriously go up again 5 minutes later. Warranty ran out one week ago...
Let's eliminate ghosts and goblins. I can't identify your unit. Give me a make and model number.
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piecr of cardboard. If you can't locate its infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try to operate it with th remote to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Apr 27, 2009 | Audio Players & Recorders
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Volume at high but sound low
Ok try turning the sound control up either on your speakers if it has volume control or go to options on the game menu and then go to sound option and turn it up, also if you are talking about that on your speaker volume control is up but sound is low try also bottom right of the screen if using windows find the little picture of a speaker, place mouse arrow over it right click and increase volume on system. Hope this helps you.
Sep 08, 2008 | Computers & Internet
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
PANASONIC SA HE9 RECIEVER 5.1
If the sub has a volume control, turn it down then turn up the volume on the amp to the very high volume you mentioned. If it still has very low muffled sound, then we know the problem is about the amp.
Apr 24, 2007 | Panasonic SA-HE90 Receiver
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Ario HC3269 32" LCD TV Logo
21 people viewed this question
Top Ario Televison & Video Experts
richie46
Are you an Ario Televison and Video Expert? Answer questions, earn points and help others
