Question about Kenwood KM010 Food Processor
KM010 locked onto one speed though dial is free moving
Had stuck when i turned back and when forced back now click into modes but is on full
How to remove blade?
If the blade is stuck on then there is likely damage to the hole inside the blade and the shaft sleeve it fits on to so you should expect to replace both or it's going to happen again and again. Brute force is going to be the answer. I have a chain that I wrap around the blade shaft where it goes onto the motor sleeve. Sometimes I secure it with a shackle or radiator hose clip then attach the other end of my chain to my workbench and accelerate the processor motor assembly away. Chain goes tight, big thump and blade flies off.
Apr 11, 2015 | Food Processors
How do I release lock mode on majic bullet?
Push down and twist.
https://www.nutribullet.com/customer-service.html
May 04, 2014 | As Seen On TV Magic Bullet Food Processor
THE FEED SHUTE ON TOP OF THE LID WAS PUSHED MIN THE WRONG WAY SO IT GOT STUCK AND I CAN'T FORCE IT BACK OUT
You just have to force it out, there is no magic. Sit down, put the lid between your knees and thump it out with the handle end of a hammer.
Sep 28, 2013 | KitchenAid Food Processors
No instructions on how to start my braun multipractic plus blende
There is a clear L shaped tab that is "in the lid" that you slides or rather you rotates into and threw a crevice slot that alows the top switch to turn on or "even move" for that matter. This seems to be a rather clever safety switch that is down right frustrating when your excited about using this machine, while thinking that we just switch it on like our lights...Safe machine...."will not work" period without the lid and bowl softly connected to the right arrow or line up markers.
Apr 17, 2010 | Braun K 600 CombiMax Food Processor
Sunbeam LC6200 won't turn off. Only runs at full speed unless the bowl lid is disengaged (the safety swtich still works). Have opened it up and the Pulse microswitch seems ok, as does the rotary speed/off...
OK this is the fix for the LC6200 that worked for me. Unscrew top cover (2 screws) then another screw holding internals to external case. Carefully remove safety switch lever (use long nose pliers from the top next to lever to squeeze plastic barb that holds the levers in to the plastic body). Remove all screws on the bottom. Open and undo the drive shaft pully nut clockwise. Pull out shaft and remove belt. Unscrew motor from chassis plate. From the bottom push out the plastic speed control dial with screwdriver. Remove motor and component boards. Check microswitches. Then remove diac DB3 and replace. Remove triac BT137 600v and replace. PS I used a 800v motorola MAC228 instead. Assemble in reverse. Good Luck.
denisprod
Feb 20, 2010 | Sunbeam Food Processors
Cannot get food bowl off the Oskar food processor
My Oskar has two locking teeth on the bottom of the bowl. One at the 3 o'clock position and one at the 9 o'clock position. Grabbing the bowl at the bottom with one hand (using thumb and one finger), I twist clockwise (to the right) about 1/4 inch and the bowl unlocks and lifts off directly. (my unit's spindle doesn't have anything to do with locking the bowl. My unit must be 15 to 20 years old btw)
Jan 13, 2009 | Sunbeam 4817 Oskar Food Processor
We can`t disasemble it with the dough blade in, any tips?
All of the blades "lock" (rest in a groove) when rotated clockwise. This is so they'll stay put when in operation. When you take the bowl out with a blade in, you're moving the pair in a clockwise direction. So, you lock the blade in, thus locking the bowl down. Either remove the blade first by rotating it counter clockwise, then up or move the blade back 1/10th of a turn after rotating the bowl as far as it will go clockwise.
Jan 02, 2009 | KitchenAid KFP750 Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Kenwood KM010 Food Processor Logo
27 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
