Question about Toastmaster TOV211 1500 Watts Toaster Oven with Convection Cooking
Stopped working, display lights off too
It stopped working and no lights are coming on at all.
What can I do as my oven stopped working yesterday whilst heating up .Both hotplates work. No lights coming on oven switch. No fan working. Help please
If the oven is not working, the fan is not working, and the light is not working, it suggests that the oven switch is faulty as that is the only common part for all 3 things. It might be a broken wire or a faulty switch. You will need to dismantle the oven to gain access to the switch and then use a multimeter to test it. if you do not know how to do this, then get an electrician or oven repair company to help, as there are dangerous voltages inside an oven than can give you a shock or kill you.
May 23, 2016 | Russell Hobbs 13824-10 Mini Kitchen with...
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
Jan 01, 2013 | Oster Toaster Ovens
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Does not heat up.
Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
Jul 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
"Err"or message with beeping
Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
Toastmaster TOV211 1500 Watts Toaster Oven with Convection Cooking Logo
Top Toastmaster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dennis Boxerman
Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
