Question about Belling XOU592 / XOU593 Electric Double Oven
I am changing the grill element ive unclipped the element at the back but the wire on the left hole disappeared av got the other now i dont know wot to do
The wire on the ieft hole has disappeared through the back got the right one just taped down plus i dont know wot the colour of the wire is the other ones white theres red grey and yellow .
2 Suggested Answers
  • 52 Answers
SOURCE: Hi there Have recently moved into
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
Posted on May 31, 2011
Testimonial: "Cheers, sounds good"
Replacing Grill element
Hello...The wires should pull thru...But be careful not to let them drop back in...If they do....you will have to go in thru the rear to retrieve them and that will be a hassle...when you replace the element..do it one wire at a time if possible but DO NOT let the wires drop back in...Let me know...I hope this was helpful....PEACE.....
Feb 09, 2012 | Ovens
Grill element - 3 connectors, which one is earth?
The earth connector will be the one that is on the left of the element in the picture and the tag that is connected to the metal case of the element which LOOKS like the upper one. The central core is the heating element and it doesn't matter which is positive of negative as it is a simple circuit.
your first link is broken.
http://stoveconnection.com.au/store/images/0122004499-01.jpg
Jul 09, 2017 | Ovens
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
We own a Bosch (Built-in) oven HBN4305.0B and the top grill/oven element has failed. Can you please advise on replacement procedure
With the power turned off it is usually a case of, in most ovens, just removing the element by unscrewing two screws. Unclip the wiring and make a note of what wires go where. Find a new one and install in reverse procedure.
Feb 10, 2011 | Bosch Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
How to change the bake element in a GE stove
Unplug or turn off all power to the oven. With most ovens you can then unscrew the element from inside the cabinet with either a screwdriver or a 1/4 nut driver. carefully pull the element out with the wires attached and dont let the wires go back through the holes. Unplug or unscrew the wires from the old element and plug into or screw onto the new depending on the type of terminal. If it is a push on type terminal make sure the connection is tight, if they are not tight pull the terminal back off and tighten the gap with pliers and recconect. put it back together and you are done. If by chance the wires are not long enough you will need to pull the stove out, remove the back panel and make the connections from the back. Good luck, it is not hard.
Dec 13, 2009 | GE Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
My grill element belling xou177 duel grill does not work, i carnt afford a new one was told be an oven specailist he would disconect wires for £30, i carnt afford this either, i need to know whic...
If you can locate the wires to the element, simply pull them off, and tape the ends of the wires to make them safe, make sure you mark them so you know where they go back.It will probably invlve you having to remove the rear panel to gain access.
Please rate my solution.
Thanks.
Nov 10, 2009 | Ovens
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Belling XOU592 / XOU593 Electric Double Oven Logo
24 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
