Question about British Telecom Lands Phones
MY BT 1000 KEEPS SAYING CHECK LINE CORD - British Telecom Lands Phones
My bt 6500 says line cord error. Please can you help me with this.
You will need to report this directly to Sky so then can run some tests on your line and if needs be they in turn will report it to BT Openreach to fix.
If you have a mobile that has free inclusive minutes with your network provider then calls to Sky via the 03 number will be free as the 03 number Sky uses now is a local rate number so would be free like 01 numbers are if you have free calls time.
Nov 10, 2016 | Office Equipment & Supplies
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
I have a bt 2500 base and phones but it keeps saying no line. The line is ok because I have pluggedcanother phone to it, caanot get a dial tone
So you have tested the line with a known good phone to know line is good. You may have issues on the port on the base where it may have corroded. Check the base where the phone line attaches and see if it appears discolored. If so try using a cotton swab and a little rubbing alcohol to clean the contacts. Another common problem I have encountered with phone cords is the locking tab breaks and thus you can have poor or intermittent connectivity. A white pencil eraser might also work to clean the contacts as well. Either way use caution as the connections in there are fragile.
Dec 02, 2014 | BT Lands Phones
Check TEL line
Is that what appears on the screen?
If so it means that it's not seeing the phone line.
1. Plug in a basic phone to make sure the line really is working.
2. Check the phone cord is connected to the correct socket (probably marked line)
3. If still no line change the cord and make sure that it suits the pin-out of your country. Most of the world uses pins 3 and 4 but the UK uses 2 and 5 on it's wacky BT flat plug. Israel uses this BT plug but uses pins 3 and 4 !!
Oct 27, 2013 | Uniden Cordless Phone
How do a leave a message saying I will be on vacation?
How to programme absent messages on Samsung OfficeServ or DCS telephone systems;
Aug 26, 2009 | Samsung Prostar DCS-24B-STD Corded Phone
When I plugged my big button phone in I got a dialing tone but when I phoned it from my mobile it went straight to 1571 saying the phone was busy. Next time I picked the phone up it was dead. It only had a...
you have a bad connection at the wall plug or on the phone cord.  Check for any loose wires or corroded terminals and clean them with an erasure.  Or as you say it a RUBBER
Mar 29, 2009 | British Telecom BT BIG Button Corded Phone
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
243 people viewed this question
Top British Telecom Lands Phones Experts
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
