Question about Lincoln Welding Tools
No power to wirefeed
I have an old Lincoln idealarc cv 400.the machine fires up but there is no power to the 115v wirefeeder.there is a fuse on the front of the machine,before the wirefeed,that I cant get electricity to.
2 Suggested Answers
  • 4088 Answers
SOURCE: While welding aluminum in AC
The machine is probably taxing the capacity of the power circuit and it's breakers. While the machine may be pulling less than 50 amps average, the high frequency modulation is likely producing peaks over 50 amps. Changing out the 50 amp breakers might help and again may not. The whole circuit should be rated at least 25% over expected current draw. The grounding system is to protect you, not the machine. Good luck!
Posted on Dec 15, 2010
I have a lincoln idealarc constant voltage model R3S 325 LN 7 control mix weld machine how often should this machine be maintenance and what is some signs that it needs to be maintenance
There is very little maintenance that needs to be done. Take the covers off of both the wire feeder and the welder and gently blow out the dirt. Do not just blast everything with air as you could create problems. If everything is working right don't worry about anything else.
Aug 19, 2015 | Lincoln Welding Tools
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
NEED A WIRING DIAGRAM FOR A DC-600
Here's your Lincoln Idealarc Owner's Manual.
If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 25, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Not getting a starting arc when foot pedal is depressed on our Idealarc TIG-250/250.
Hi:
The foot control has a micro switch in it, this one must be worn out. Take it to your nearest werlder shop (like praxair... www.praxair.com ) and ask for the microswitch by brand and model of your foot control. It's easy to replace. Probably the welder shop must order it, since it's noy pretty common for this switch to go bad, but it happens, specially on old welders.
Jun 22, 2011 | Lincoln Electric Welding Tools
While welding aluminum in AC mode (with continuous high frequency), the 50 amp circuit breaker in the house emits a loud buzzing. The machine is electrically grounded to a 8 foot grounding rod. Anny...
Dec 14, 2010 | Garden
Wiring diagrams for lincoln sa-200 F-163 welding machine
try Westermans - used welding machines supplier. They stock the best brands like Lincoln, ESAB, Kemppi and Fronius. They should also have operator manuals for most machines. email them at welding@westermans.com ask for Craig.
Sep 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Lincoln Idealarc tig 250 has no high frequency
Check high voltage transformer and capacitor, also check point gap circuit to ground.
Jun 20, 2009 | Welding Tools
CP 302 wlder
Trigger the wirefeeder while listening for the contactor on the CP302 to close, if it does start looking for loose, bad or missing ground connections to the work, then look for the power connection from the CP302 to the wirefeeder to be bad. If the CP302 contactor doesn't close look at the control cable between the wirefeeder and the CP302, try a different one if possible. If you hear the contactor close, and everything else is good, check the voltage at the CP302 output terminals to see if you may have a bad contactor.
Oct 29, 2008 | Miller Electric Mfg Co 903376 Deltaweld...
Welding Tools Logo
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
