Question about Otto Navi GPS 05-11 2005 2006 2007 2008 2009 2010 2011 TOYOTA TACOMA IN DASH DOUBLE
Password code Need code to pair my phones
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
Jun 05, 2011 | Samsung Cell Phones
I need to send a password from the phone to the car how do I imput it on the phone. the password is 1111
Power on the Bluetooth on your car stereo and MP3 player or cell phone. The Bluetooth may always be on in your car, but it may be disabled on other devices to conserve battery power.
Open up the menu of your cell phone or MP3 player and have it "discover new devices."
Select your car stereo from the options your device provides.
Enter in the "Pairing Code" for your car stereo into your device. In most cases you will find the pairing code in your car's manual. if you don't know the code try using all )'s.
Try playing a song once your device indicates it is paired with your stereo. If it doesn't work try
Steps 2 to 4 again.
Use 0000 instead.
Thank you.
Mar 12, 2011 | Cell Phones
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
Need a pairing code
a pairing code is simply a code you put in or type in the main device like a cell phone that you should also type or put in to the other deice or phone.
Example, you want to pair via bluetooth a cellphone and a laptop. When you attempted to pair your laptop to the phone, you will be prompted for a code in your laptop: you enter 1. And then you will be prompted for a code in your phone and just enter 1, the same with what you first entered in the first device. It is not a fixed number or code like a password.
Dec 29, 2009 | Cell Phones
Pairing my bluetooth
most bluetooth headsets pairing codes are either 4 zeros or 6 zeros.
if you need anymore help we are here to help! Call us M-F 9-6 Sat 11-2 317.337.0030
Nov 11, 2009 | Cell Phones
What does it mean when i get password mismatched in the Bluetooth pass code?
password are for security and privacy reasons..
missmatched password while pairing bluetooth devices means you have entered incorrect pass code.
usually the the device A you are searching with asked you to create a pass code when you are pairing device B. When connection is establishing, device B will ask you for the pass code you just created for pairing device A with device B. this pass code is different for each and everytime you connect to a device.
Nov 05, 2009 | LG Vu CU920 Cellular Phone
Otto Navi GPS 05-11 2005 2006 2007 2008 2009 2010 2011 TOYOTA TACOMA IN DASH DOUBLE Logo
21 people viewed this question
Top Otto Navi GPS Car Audio & Video Experts
xxxxxx xxx
Are you an Otto Navi GPS Car Audio and Video Expert? Answer questions, earn points and help others
