Question about Galaxy Radios DX29HP 6 Band 10 Meter Mobile Radio
Fm adjustmet for the galaxy dx 29hp - Galaxy Radios DX29HP 6 Band 10 Meter Mobile Radio
  • 60 Answers
Do you mean the FM Deviation or Detector Adjustment? I haven't found a schematic on the DX29HP yet but it may be the same as the DX33. NO GAURANTEE! The DX 33 has VR5 as the FM Deviation. You'll want to borrow or buy an FM Deviation Meter to adjust that. The FM Detector is L5. You'll need to Connect an AF VTVM or scope to IC2 Pin 7. In FM, Set FM RF Generator to 26.965 MHz (CB Channel 1) and at a level of .5uV deviated 3 KHz with 1KHz audio tone.
Reduce the volume as you need to. AGAIN!!! THE DX29HP MAY NOT BE ANYTHING LIKE THE DX33. If you are not sure, please pay someone to make the adjustments for you. It's a pretty nice little rig.
Posted on Feb 21, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: how to add a 10k switch to a galaxy 29hp radio?
Apply 8 volts to the rear pin of the connector to the right of IC4. I would use the talkback switch. I haven't seen a 29hp yet but I believe it uses the 6900 board used in most of the new Galaxys.
Posted on Jun 29, 2011
Galaxy 29hp no key up
You're probably savvy with radios so don't get mad if I ask you to check the PA Button. If the radio receives, it's obviously not that. Probably a bad final or a bad AM Regulator.
Jul 01, 2014 | Galaxy Radios Microsystems DX33HP CB Radio
Set the carrier on the galaxy 55hp
you need a watt meter,a static proof screwdriver and a schematic. www.cbtricks.com has the service manual
May 16, 2014 | Galaxy Radios Dx-55hp Am/fm Transceiver...
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
I have a galaxy DX 44 that on the AM side after it been on for like 10mins the AM side goes out but the FM side don't
you probably have a thermal problem.Get some mr.freeze and try it again .when the radio goes out spray some Mr.Freeze onto the final area.Just a dash will do,don't want to freeze the parts just want to cool the down quick to see if the radio comes back on. If it does go to the final when it goes back out and spray a little on it .If it comes on then change the final and problem almost solved. Now wait to see if it goes out again , If it does then you have to get a block diagram to work from and spray some Mr.Freeze on the main IC while you're at it. If it comes on then it should be changed .Now that everything is new it had better be working but if not start spraying other componants until the radio comes on and stays on .
Mar 25, 2012 | Galaxy Radios DX-44V 40-Channels Base CB...
How to add a 10k switch to a galaxy 29hp radio?
Jun 11, 2011 | Radio Communications
I have a galaxy 44v it transmits on fm but receives on am what can i do to fix this problem
Replace the AM final, then make sure your antenna is tuned to lowest SWR to prevent the final from burning out again.
Nov 24, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Fm mode inoperational
can you please tell where is the other end of the wire is connected to... coz i believe that you are mistaken the wire that these FM use as antenna.....
Jan 31, 2008 | Galaxy Radios DX 77HML Base CB Radio
Galaxy Radios DX29HP 6 Band 10 Meter Mobile Radio Logo
78 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
