Question about Sanyo Audio Players & Recorders
Sanyo awm1900u how to set clock
Sanyo katana cell phone alarm clock goes off hour earlier than se
when you set the alarm make sure that you scroll to the bottom and in the preferences you can choose to make it no minutes before for up to 24 hours. this usually happens when you use the calendar alarm instead of the phones alarm
Feb 03, 2010 | Sanyo Katana Eclipse X Cell Phone
Sanyo EM-S1567 set clock How to setup clock on it?
The owner's manual is online free here.
Dec 25, 2009 | Sanyo Microwave Ovens
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
Sanyo Hi-Power 50Wx4 FXCD-1350 CD-R/RW setting the clock
Press the DISP button for more than two seconds,then to adjust mins.press the > button,to adjust hours press the < button.Press the DISP button again to start the clock.Please don't forget to rate, Thanks.
Apr 09, 2009 | Sanyo FXCD-1350 CD / Cassette Player
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
Sanyo Micor/Oven/Grill EMG2553S Clock
You can download your owner's manual here.
Aug 29, 2008 | Sanyo EM-G2585W Microwave Oven
Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Sep 23, 2007 | Sanyo AVM-3659S 36" TV
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
53 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
