Question about Chef's Choice 677 Cordless Electric Kettle
Torn filtering screen for model 677 electric kettle
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
How can I get a replacement switch?
Kettles these days are pretty much a throw-away items these days.
You could try the distributor though
http://www.chefscatalog.com
Oct 11, 2015 | Chef's Choice 677 Cordless Electric Kettle
What level should water be at before turning unit on?
There should be a line to show you on the inside of the kettle where the watermark is.
Sep 02, 2014 | Chef's Choice 677 Cordless Electric Kettle
My kettle is turned on and the switch lights up but it does not heat up.
in this case i would say the element has burned out they are not a servicable unit and would be cheaper to replace than fix
best of luck.
Aug 03, 2010 | Chef's Choice 677 Cordless Electric Kettle
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
The spout filter in my Toastmaster TEK17W kettle has torn. Where can I get a replacement
The filter for a Melitta MEK17W or Toastmaster TEK17W (identical kettles)are the same.
If you still have the old original filter, here is the link to an inexpensive and permanent repair option using stainless mesh:
Aug 13, 2009 | Toastmaster (TMHP2) Electric Kettle
Chefs choice electric kettle 677 works sometimes
I have the same problem and I tried to open the base to clean the contact points but found that it is molded into one piece and would have to be cut open and then glued shut when finished. I am about to pull out the file for the kettle contacts because its headed for landfill If I do nothing so I cant make it worse. I am going to file the contacts until itere a little shiny.
Nov 22, 2007 | Chef's Choice 677 Cordless Electric Kettle
Chef's Choice 677 Cordless Electric Kettle Logo
56 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Rommel Balcita
Tom Chichester
AJMAL KHAN
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
