Question about Otto Navi GPS 05-11 2005 2006 2007 2008 2009 2010 2011 TOYOTA TACOMA IN DASH DOUBLE
Need Bluetooth password
Need password code for pairing my phones
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
Jun 05, 2011 | Samsung Cell Phones
Tip
How can I find a Bluetooth Passcode?
<p>Bluetooth is a quick and easy way to wirelessly connect two electronic devices. Bluetooth is commonly used for mobile phones and PDAs to hands-free devices like headsets and hands free connection, but can also be used to connect these devices to computers and MP3 players. Two Bluetooth devices, you need the password, or "pairing code" to find the equipment to connect. Finding it is generally very...<br /> <p> <br /> <p>1. Look on the back of your headset or speakerphone Bluetooth device password. Normally the pairing code is printed on label headphones which are then placed at the bottom of the accessory. <br /> <p><br /> <p>2. Go to the Bluetooth menu on your phone with the password to your cell phone to find. The Bluetooth menu of your phone is usually located under the "Settings" menu. On the Settings menu, there should be an option to "Get code" or something similar, allowing you to get the code for your phone to find. <br /> <p><br /> <p>3. Go to the Settings menu of your computer to find the Bluetooth passcode. Some laptops will randomly generate a new password for your Bluetooth every time you want to link them to a new device. In this case, the configuration menu you are looking for is something like "pairing Generate a new code." <br /> <p><br /> <p>4. Check the manual for your Bluetooth if you cannot find access to the device or on your menu. Many manufacturers have pressed for access devices in your manual. If you still cannot find the password, try all zeros. <br /> <p><br /> <p>5. Look at online forums for the password to your phone if you still have trouble finding it. A Google search like "Nokia N98 Bluetooth pairing code." This research will typically take you to a forum or help page that the link code for your device will. <br />
on Jun 26, 2011 | Cell Phones
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Please give us a bluetooth wirless device EVERE T909S pairing code. we have lost over booklet and forget our pairing code
You need to press the Bluetooth logo "On" button to turn it on but keep holding it down for a longer time until the red and blue lights start alternate flashing, pairing the headset before entering the, password: 0000.
Dec 13, 2010 | Cell Phones
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
Pairing my bluetooth
most bluetooth headsets pairing codes are either 4 zeros or 6 zeros.
if you need anymore help we are here to help! Call us M-F 9-6 Sat 11-2 317.337.0030
Nov 11, 2009 | Cell Phones
Pairing bluetooth to my phone
  • general instructions for no specific phone and device to pair
    • turn on both devices (phone and other device)
    • on the phone search for a bluetooth devices(that is on)
    • if the other device is asking for a password, enter a known password to success the pairing
    • or else it will pair automatically for a non password pairing
May 03, 2009 | Lands Phones
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Apple ifone bluetooth
you have to make sure that bluetooth is turned on.
go to your home screen, touch settings, then general, then bluetooth, make sure the bluetooth switch is set to on.
Then follow your directions for the your headset for pairing, usually it involves holding the power button down for so many seconds, then it will enter a "pairing" mode where the headset is able to be seen by phones.
Once that happens it should pop up on the bluetooth page of the iPhone and it will ask for the devices password. Most devices the default password is 1111.
Hope this helps and enjoy your Iphone, I know I do ;)
Dec 10, 2007 | Apple iPhone Smartphone
Otto Navi GPS 05-11 2005 2006 2007 2008 2009 2010 2011 TOYOTA TACOMA IN DASH DOUBLE Logo
10 people viewed this question
Top Otto Navi GPS Car Audio & Video Experts
xxxxxx xxx
Are you an Otto Navi GPS Car Audio and Video Expert? Answer questions, earn points and help others
