Question about 2001 Ford Mustang - GT - Form Fit Car Cover
Idling too high
When start the car idles up over 2ooo then goes down and stays idiling at a little over 1000
    Problem Solver:
  • 15 Answers
Hi, is this happening just when you start the car in the morning? Or any time?
Posted on Feb 10, 2014
Toyota corolla hatch 2002 idle at 2000 rpm when
All the above is normal , except 2000rpm is a little high at idle . can be adjusted down to 1500rpm. the computer adjusts the engine speed . in drive the transmission loads up the engine idle drops to 1000rpm . in park engine unloaded rpm increase all normal.
Sep 17, 2014 | Cars & Trucks
Idils to high and then goes up and down
Hi Bobby i had a 2004 caviler did the same thing the code that came up was idle air control valve but after replaceing it i got the same code with check engine light on. And idle going up and down with high idle! turns out the brake power booster had holes in it on the back side of it the side that faces the firewall. The best way to check is to pull off the vacume line that goes to the brake booster and put your thumb over it and see if the idle goes down! If it does that,s your problem. also check all vacum lines! Hope this helps you out... Ed
Apr 11, 2014 | Toyota Pickup Cars & Trucks
My 1997 grand prix idiles high when you start it stays at 2to 3 grand on r.p.m
The most common causes of high idle speed is a faulty idle air control valve, a sticking throttle cable, or dirty throttle body.
It could also be a vac leak, but that usually does not come and go.
Apr 20, 2013 | 1997 Pontiac Grand Prix
Rpm does not drop below 1000
No,only on carburated engines it,idles down to the set point,on yours,it's fuel injected,pushing gas pedal won't kick idle down,should go down after a certain amount of time,does it automatically,If you start and drive a 5 mile ride and stop at a stop sign,it should idle at it's set point if there's no engine problems,which may be.5 to .7 on your tac.When you normally first start,it will idle between 1000 to 1200 rpm's,don't push on gas,let idle say 15 seconds,put in drive and go.
Jan 13, 2013 | 2005 Chrysler Sebring Conv
The idle is staying around 900-1000 for the most part went to 1500 last night but went back down it seems a little high also my temp at idle is around 190-210 than when I drive it goes to around 180-
well it sounds like your thothle could be sticking need to clean it with caborator cleaner or check your idle with timing light to see hows your timing is....
Oct 05, 2012 | Cars & Trucks
High idile
turn the idle down. you need a flat head screw driver and find the idle switch and turn it down.
Dec 30, 2009 | 1989 Jeep Cherokee
1986 subaru gl wagon non turbo stays idiling at 2500
Hate to tell you this but sounds like the problem is a vacuum leak. This will make the engine rev. Check all the vacuum lines before making any adjustment. Have to dig out some of my old books to find factory settings for that carb. Good luck and I will try to find in case you need them to restore carb settings.
Apr 13, 2009 | 1986 Subaru Gl 2 Door
Idle problem
turn the idle screw down on the carburater
Feb 17, 2009 | 1988 Honda Accord 4 Door
High fast idle at start up.
On most newer cars there is a fast idle motor controlled by the computer that will hold the fast idle till the engine reaches a preset temp in the computer then the engine should drop down to the set idle according to specs for that car. If the oil pressure continues to stay low after the idle goes down you may need to replace the oil pressure sending unit or if worse case the oil pump.
Nov 18, 2008 | 2003 Hyundai Tiburon
Chyrsler sebring lxi 1995 2.5 v6 24 valve
ok this sounds easy when you ran the vehicle the computer controled the idiling motor now that you replace the idiling motor the computer hasnt been reset to except the new parameters
once you reset computer this should bring the idle back down to its specified idle
you can also adjust back of gas pedel the idle cable and on the throttle body by the idling screw
Jun 13, 2008 | 1995 Chrysler Sebring
2001 Ford Mustang - GT - Form Fit Car Cover Logo
54 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
