Question about Tefal Actifry Fz700015 Low Fat Electrical Fryer 1kg Capacity
Remove power cord connecter actifry
How do i replace the power connector
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Why does nothing past the first connector work?
Check for broken wires/connections on both sides of the connector.
Nov 30, 2015 | One Stop Gardens Solar Rope Light
Il affiche printer error service call6000
problem is with fuser,Code Error indications Contents
Check procedures/corrective measures
6000 Fuser unit error
Yes
Yes
Yes
No
No
Turn power switch off,
and remove power
cable.
Detach connector CN4
on power supply unit.
Detach connector CN1
Measure resistance
between pins 1 and 2
of the detached
connector.
Replace fuser thermistor.
See page 1-6-25.
Replace thermal cutout or
heater lamp. See page 1-6-
26 or 1-6-22.
Replace bias PWB (K0009)
or high voltage unit or power
supply unit. See page 1-6-13
or 1-6-12.
Open (infinite)?
No
No
Open (infinite)?
Measure resistance
between pins 1 and 3
of the detached
connector.
Replace harness
(2FM2601) between engine
PWB (K0010) and bias
PWB (K0009).
End.
Yes
No
Replace engine PWB
(K0010). See page 1-
6-9.
"6000" error
shown?
"6000" error
shown?
START
Feb 03, 2014 | Kyocera Mita Fs-1016 Mfp Multifunction;...
I bought a new tefal actifry family Ah9000 and when open the box and connect it to power then pressed on/off button nothing happened. Just a green screen with hardly to see sun shape on the left side
Use the timer. Unlike the Actifry and Actifry Plus models, the timer on the Actifry Family controls the fryer, and turns it off at the end of the cooking time.
Jul 20, 2012 | Tefal ActiFry Deep Fryer
My actifry is not working its dead it seems it has no electricity at all?
If you remove the base (3 star screws), you will see that the live cable has a bulge in the cable wrapped in black heatshrink. In the bulge is an in line glass fuse (8a). which you will need to replace or bypass (not recommended).
Apr 01, 2012 | Tefal ActiFry Deep Fryer
Kyocera FS-2000D error 6000:0087166
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this:
There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code.
You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board.
also Check the power at the wall outket. Low power will cause 6000 errors.
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
Burnt connector inside dell inspiron, first connector at motherboard (after power box) Can I fix it?? If so, can u help??
LOVE your user name!
I'll try to guide you the best that I can.
Sorry, first connector after Power Supply does me no good.
Let's look at a basic schematic of the motherboard for a Dell Inspiron 530s Desktop PC,
Dell Support > Inspiron 530s Desktop PC > Dell Inspiron 530s Series Owners Manual,
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/index.htm
I would like you to click on - Removing and Installing Parts
In the left column click on - System Board Components
{System Board = Motherboard }
This is a basic view of the motherboard with No hardware components installed.
It is also how the motherboard sits in your computer.
This is a pictorial view of the motherboard,
http://www.amazon.com/Dell-Motherboard-Inspiron-Systems-Compatible/dp/B003CO0WQS
Now, compare the Dell Support motherboard illustration, to the pictorial.
Looking to the far right in the illustration, the first connector is marked with the number 8.
On the pictorial it is the rectangular Black connector at the bottom/middle. (Next to the rectangular White connector)
This connector is for a Floppy Drive.
Is this the connector in question?
Is it the white rectangular connector next to it?
This connector is for the main power cable coming from the Power Supply.
In the illustration is is marked by the number 7.
This is a basic example, of the power cable coming from the Power Supply (power box), that connects to the white connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
{Note* Color of the main power cable's connector does not matter. It can be any color }
IF this connector on the motherboard is burnt, you may wish to stop.
Electricity has more than likely fried the entire motherboard. May also include the Processor, Ram Memory, Harddrive, and a graphics card, if installed.
I know. I'm a 'ray of sunshine'.
How could this connector be burnt?
Four ways I know of;
1) Lightning storm, or power outage. Also could have happened if the power utility company was doing some changes in the power lines, utility pole transformer, etc.
(No. The utility company cannot be held responsible. I don't agree with that)
2) Power cable was not plugged in tightly. Lock on side was not locked into place.
Air gap created in-between the connecting contacts in the power cable connector, and the motherboard connector, created resistance.
Resistance creates heat. Burnt connector/s will result, and perhaps worse.
{Could also create a small power surge }
3) At one time Dell was a Proprietary computer manufacturer.
This means Dell wanted THEIR replacement parts used on THEIR computers.
If an aftermarket computer component is installed, Dell cannot warranty their computer.
Using THEIR parts in THEIR computers, Dell could.
However Dell computer users did not wish to pay the price of the Dell replacement parts.
The aftermarket parts were cheaper, of good quality, and readily available.
If we use a Power Supply for an example;
Dell had the motherboard manufacturer switch the socket holes around, in the Motherboard connector, for the main power cable.
They also had the Power Supply manufacturer switch the pins around, in the 24-pin ATX main power cable's connector, to match.
The aftermarket power supply manufacturer built the power cables, and connectors, to follow industry standards. Dell did not.
This means if you plug an aftermarket power supply's main power cable, into a Dell motherboard that was built proprietary, the motherboard usually fried. The only sign may be a burnt connector on the motherboard.
Could also have fried the Processor, Ram Memory, Harddrive, optical drive/s, and a graphics card, IF installed.
[ Looking at the Playtool link again, look at the photo to the far right.
See the different colored wires?
The color coding indicates what the wire carries as far as Voltage, or if it is a Ground wire.
1) Orange insulated wires = 3.3 Volts
2) Red wires = 5 Volts
3) Yellow wires = 12 Volts
(All are DC. In comparison two D cell flashlight batteries produce 3 Volts DC)
4) The Black wires are Ground wires
(The Green wire is the Soft Power On wire. Abbreviated as PS_ON)
The Orange, Red, and Yellow wires are power wires.
The Black wires are Ground wires.
Guess what happens if a 12 Volt wire is connected to a Ground?
(Instead of going to a 12 Volt connection)
Things start frying.
{To state connections in the main power cable connector, and it's respective connector on the motherboard, correctly;
Looking at the middle photo you see the connection end of the main power cable.
Plastic connector with individual plastic rectangular shapes, that have metal 'tubes' inside each of them.
The motherboard connector has socket holes to match the individual plastic rectangular shapes.
Inside the socket holes are metal pins. Contact pins.
The contact pins go inside the metal 'tubes'.
The metal 'tube' is a Molex Socket Terminal,
http://www.mouser.com/ProductDetail/Molex/36664-0002/?qs=sGAEpiMZZMvz8LftK4jerhl0r50z%252bUNRzFCdHbJqUTU%3d
4) IF the Power Supply, ( looking at it from the Back of the computer), has a rocker switch, or slide switch, to set the incoming AC power to 110 Volts, or 220 Volts;
And the power supply switch was set to 110, and plugged into 220 Volts,
the motherboard connector would fry.
Plus the Power Supply. May also of course include Processor, Ram Memory, Motherboard, Harddrive, optical drive/s, and graphics card IF installed.
Replace the connector? No
Could be;
A) Replace the Power Supply. Still no?
B) Replace the Motherboard. Still no?
C) Replace the Ram Memory. Still no?
D) Replace the Processor. Computer operates but no graphics?
E) Graphics card installed? Replace graphics card
Unless you can test each individual component, and the cost is not much less, or equal to a new computer, the obvious choice would be to purchase a new, or good used computer.
Nov 01, 2011 | Dell Inspiron 530s Desktop Computer
My tefal actifry has stopped heating as the paddle rotates can you advise me
You have just two options:-
Return the unit to Tefal for a repair under warranty, or claim under a separate product warranty.
If you have no warranty then your only fix is to replace it with another ActiFry. But as they're notoriously unreliable you might choose not to.
There is almost nothing user-fixable on the ActiFry and it has not been designed to be repaired. They have about a 3 year maximum lifespan assuming an "average" domestic usage cycle, and far less if used every day.
Sep 23, 2011 | Tefal ActiFry Deep Fryer
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
The t.v powers on for just a second and clicks off. I can hear a click from the back and it recycles off/on over and over.
open the set remove all but the ac cord connectors from the power supply; label them first! turn on the tv if the power supply does not recycle turn off the set and, connect and, disconnect each cable one at a time going to the power supply turning the set on and, off each time as you test until the power supply cycles (fails) again then repair or, replace the circuit board that causes the power supply to fail. if the power supply cycles on and, off (fails) with all connectors but, the ac cord disconnected repair or, replace the power supply.
Jul 19, 2010 | LG 42PC3D 42 in. Plasma Television
Tefal Actifry Fz700015 Low Fat Electrical Fryer 1kg Capacity Logo
60 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
