Question about Frigidaire Washing Machines
What does werror code e20 mean
The error code 320 keeps coming up on my washer I don't know what that means
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Check your filter if that is clear check your pump
Posted on Feb 11, 2014
Coldcut
  • 1554 Answers
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Posted on Jan 29, 2008
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
  • 3 Answers
SOURCE: firgidaire washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Posted on Apr 07, 2008
SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Posted on May 28, 2008
SOURCE: Zanussi
 The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
Posted on Oct 31, 2008
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
GE Washer Model ## WPSB9220D0WW Data Code31704 Error Code E43 Drive System Excessive Brake Time My washer don't do anything but show this error
On GE Washer Machines, E43 error code means "excessive brake time". The brake and speed sensor will need to be checked. You can try resetting the machine by disconnecting the power for 20-30 minutes. Keep in mind that your right model number is WPRB9220D0WW.
You can eliminate if it's the speed sensor by entering the service model. To do this:
- Turn off the washer at the power pad
- Remove power by unplugging the cord for 15 or more seconds
- Plug back in and within 30 seconds simultaneously press and hold the POWER and START pads for 3 seconds
- Should now display the model codes
- There are a bunch of tests but we are interested in the spin fast portion, so press the custom 2 pad until the display shows SF ( Spin Fast )
- Hit START pad... it should start spinning and display the rpm's
If it does this the speed sensor is working and the problem is the brake which means the transmission has to be replaced. Parts replacement can be find in THIS LINK.
If you do not feel able to resolve it, we recommend you call the technician to do it. Now you know what the problem.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 10, 2011 | GE Washing Machines
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
320 Cat Excavator- engine idles, but does not power up, black smoke come out. Checked the turbo , it's okay. ??????
320 D Excavator Bzp ..., start-up cannot on , there is
error 39: 590-9, please how to solve this problem, what should I check
Sep 03, 2010 | Caterpillar American Construction...
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Error codes
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error code F11 and orthers
gailo, F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again. Catriver...post back.
Oct 29, 2006 | Kenmore 45981 Washer
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
