Question about Dell Latitude E4200 Notebook
Stucl on system recovery
Well im just stuck on a system restore ..and its on a loop
  • Dell Master
  • 1,087 Answers
You could try tapping the keys Ctrl+Alt then Del - this brings up Windows Task Manager. Select the task that says something about System Restore and say OK.
If it fails to come up you will probably have to cross your fingers, and turn off your notebook, and reboot using F8 safe start.
Posted on Feb 09, 2014
Computer won't start. Message keeps saying " attempting to restore Windows" but seems to be in a loop. What can I do
I hope this will help
Method 1. Reset your Windows 10 PC
Navigate Start > Settings > Update and Security > Recovery > Reset this PC.
Then Hit on the Get Started button just below the option to fix Windows 10 'Restoring your previous version of windows' stuck issue. During the process, select Keep my files option will allows you to keep all your personal data safe.
Method 2. Perform a System Restore or Startup Repair
1. Download Windows 10 media creation tool and create a Windows 10 installation media.
2. Boot or start your computer from the Windows 10 installation media.
2. In the Install Windows page, tap 'Repair your computer' to start the Windows Recovery Environment.
3. In the Windows Recovery Environment, on the Choose an option screen, click 'Troubleshoot'.
4. Click 'Advanced Options' and then click on 'System Restore' or 'Startup Repair'.
Then follow the on-screen instructions to fix Windows 10 'Restoring your previous version of windows' stuck or loop and restore the computer to an earlier state successfully.
Method 3. Clean install Windows 10 with ISO image
If none of the above methods is helpful, you can try to reinstall Windows 10 with ISO image file. Just download Windows 10 media creation tool. Try it to download Windows 10 ISO image file and burned it to bootable DVD or USB flash drive. And then clean install Windows 10 on your PC. It has helped most users to fix Windows 10 stuck at 'Restoring your previous version of windows' loop.
Method 4. Restore Windows 10 using previous backup image
The above methods are all the possible free solutions from Windows 10 settings to fix Windows 10 stuck at 'Restoring your previous version of windows' loop. Actually, at most times, they might not help due to certain reasons. So we strongly recommend you to backup Windows 10 system with EaseUS Windows backup software. It can help you easily and quickly restore your system from the backup image without losing anything when a disaster happens unexpectedly.
Feb 08, 2018 | Computers & Internet
Medion problems
Hi
Run a chkdsk from the command prompt, once you have done this see if you can get on in safe mode and then restore it to a time before the update attempted to install
Cliff C
Aug 23, 2014 | Medion Computers & Internet
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
Compaq nc8230 stuck in startup loop after system restore to earlier date
on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter
Mar 13, 2012 | HP Compaq nc8230 Notebook
Iphone2g with 1.1.4 firware, jail broken is stuck in recovery loop...when i tried restoring it gives error code "28"....please help...
possible hardware issue. try restoring on other computers, use other cables, and if using a desktop computer, use the back usb port.
Jan 27, 2011 | Apple iPhone Smartphone
I CANT LOAD MY VISTA DISK im trying to re install vista home but my computer keeps looping
If you have not changed the preinstalled OS in the computer, the recovery partition in the computer will be still intact. In that case, you can use the recovery partition to perform a system recovery. Please restart the computer and press and hold the F10 key. This will launch the recovery partition and from there, you can select "Restore C Drive" to perform a system recovery.
As you have mentioned that you are trying to perform a system recovery using the discs(which i understand is recovery discs for the computer), I suggest that you check if the Boot sequence is set to CD/DVD Drive in the BIOS and then try again.
Thanks!!!!
Dec 30, 2010 | Sony VAIO VGN-NR285E/T Laptop
Restart
it is stuck in a loop, when it is rebooting turn it off at the power button on your pc.
Turn it back on, then it should say windows shutdown unexpectidely and then prompt you to start windows as normal, highlight it and press enter.
Sep 08, 2008 | Microsoft Windows XP Professional
E Machines
In this situation I would start by testing the hard drive then the RAM.
For the hard drive find out the manufacturers name and download their test program.
For the RAM test I have used a free program call memtest86 with very good results.
If the problem is the hard drive, you may be able to install a hard drive of the same size and using an imaging program copy the old drive to the new drive. Re-run the recovery program. My suspicions are that the old drive has developed bad clusters near the beginning where the operating system is and some of the files have become corrupt.
If the RAM fails the test replace the RAM and try again.
Apr 27, 2008 | Dell PowerEdge 2500 Server
Dell Latitude E4200 Notebook Logo
Alun Cox
