Question about Thermador SEC301 Electric Single Oven
F24 error on Thermador Oven sec301 - Thermador SEC301 Electric Single Oven
4 Suggested Answers
SOURCE: F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Posted on Nov 25, 2008
SOURCE: I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Posted on Jan 25, 2010
  • 1456 Answers
SOURCE: Thermador Model C302 Convection Oven
Hello
"F -24" error code means the keys on the control panel were pushed or touched for longer than 60 seconds. Leaning against the oven or hanging objects in front of the controls can cause these error codes to appear. To fix this,turn the oven off and wait three minutes before turning it on again.
If the code keeps displaying then the problem is that you have a "Touch Input Key Stuck" it could be that the touch pad got weak from constant pressing or just made inferior.. Now with that in mind the fix is to replace the power relay board and the touch pad. You should start with replacing the touch panel first. This is probably the more likely suspect. Then if that don't work replace the power relay board.This is not a cheap fix.
To get your model number usually if you open the oven and look in the top between the grill, right above the door you can see a tag with the model number. You will need a flashlight and good eyes.
To stop the beeping,you have to disconnect the power to the oven.
Posted on Apr 17, 2011
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
Oven shuts off during warm up and gives an e error
and just what is the error? the code is what tells us where the problem lies.
Feb 22, 2014 | Thermador Ovens
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
My Thermador RDDS30VRS only heats up to 230 degrees
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Sep 07, 2011 | Thermador SEC301 Electric Single Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Thermador SEC301 Electric Single Oven Logo
57 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
