Question about Fujitsu LifeBook E8310 Notebook
Change wireless controller E8310
Change wireless controller for a new one
E8310
Hey;
Usually when the PC flashes the scroll lock key, it indicates that the memory modules are bad, or the motherboard needs replacing. You didn't specify if the laptop turns on or not. Usually with this problem, it does not turn on.
Feb 02, 2014 | Fujitsu LifeBook Computers & Internet
Atheros AR5007EG can't connect via WPA2 to WLAN on Windows XP
WPA2 is considered insecure and hacked years ago.
You might try WPA, or get a different Adapter.
Mar 03, 2018 | Fujitsu Siemens Computers & Internet
Mousepad is locked and cannot use wireless mouse
Hi
please try pressing the FN+F7 keys both at the same time this may un lock the mousepad
or look on or around the keyboard for a key that has like a little finger on it this could be the mousepad lock\onlock key
many thaks
Jul 24, 2011 | Fujitsu LifeBook E8310 Notebook
By error i have installed a dell system driver since then however i formatted my lifebook e8310 ihave problems with mouse touchpad and bleu dsplay
~To download drivers and specific software;
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the fujitsu.com web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Feb 13, 2011 | Fujitsu LifeBook E8310 Notebook
Ik heb een E3810 van fujitsu maar er zit een wachtwoord in de bios hoe kan ik die reseten
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Jan 27, 2011 | Fujitsu LifeBook E8310 Notebook
My ps3 will not recognize any wireless controllers or blue tooth devices. My Ps3 BD controller, headset and six-axis will only work connected via USB. I tried the reset buttons on the six-axis but does...
Did they connect before and now won't or are these new bluetooth set up connections? If new connections:
  1. In the XMB™ home menu, go to [Settings] > [Accessory Settings].
  2. Select the "Manage Bluetooth® Devices" option to register (or "pair") a Bluetooth-compatible device with the PS3.
Dec 03, 2017 | Sony Wireless Controller for PS3
I have no sounds and when I open the control panel, there's that i have no sound device. I installed the driver, when it didnt work I reinstalled it, but nothing changed. what can I do?
  • Hi, the best thing to do at this point is perform a "System Restore." Try to remember the exact "Date" before the problem occur, or once you start the System Restore, ("pick a date going back more than 5 days"), check the dates and see if any of the dates seem familiar. Pick the closest date prior to the "Sound going out!" Type: in the "Start Search Window" from the start menu: system restore; scroll to find, and open. Follow all the instructions carefully, and be very "patient," you cannot use the computer in any way during the "system restore" even after the computer "Restart" the system restore is still running to "fix the problem." When the process is finish the computer will let you know if the restore was successful or not? Do what is suggested if the restore didn't fix it." "Hope it works out for you; if so rating the help will let me know, thanks."
May 14, 2010 | Fujitsu LifeBook E8310 PC Notebook
My xbox 360 wireless controller won't turn on at all?
did u try changing the battery?
if thats not it then i think its just broken... u should get a new one?
brit
Feb 21, 2009 | Microsoft Wireless Controller for Xbox 360...
Not connecting
There should be a switch on the Pelican wireless controller that enables you to change the channel on the controller and or receiver. Look in its manual, it should say such. If not... Then it's because it is a very poorly-done job done by the company. Replace that controller with a WaveBird (older wireless controller for the gamecube, but a lot better)
Please keep your X-Box controller question in another section.
Aug 03, 2008 | Video Game Consoles & Games
Fujitsu LifeBook E8310 Notebook Logo
32 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
