Question about Radio Communications
On a head set logitech h470 i am not able to recharge the batteries & will not work ven f pugged to power supply
  • 5 Answers
SOURCE: DELL Inspiron 5150 won't charge
either a power supply problem within the motherboard or you need to replace the plug on motherboard
Posted on Aug 22, 2009
SOURCE: I have 2 Logitech 890 remotes- neither one will
Units are not servicable, so replaced them
Posted on Dec 25, 2009
  • 7993 Answers
SOURCE: tom tom 125.se will not recharge battery threw my
You have another option. Connect the GPS unit to a USB port on a computer. And please use the USB cable supplied with your unit.
Posted on Jan 04, 2010
  • 5 Answers
SOURCE: power goes off!
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Remember that if the audio to the transmitting unit is quiet OR off for about one minute, the transmitting unit will turn off and you will hear FM noise, loudly, on your headphones. This is due to the "lack of audio" timer built-in to the transmitting unit.
Posted on Sep 05, 2010
  • 212 Answers
SOURCE: hi, I have a Dell
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
Posted on May 19, 2011
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
Batteries will not recharge on stand. Have used different rechargeable batteries but same result
It could be the metal contacts that's used for recharging the mouse that isn't making a proper connection. The most common cause for this, would be dirt & oil that would build up on the charging contacts over time.
I would try to clean the contacts with a dry tissue paper on both the mouse and the charging stand and see if the mouse will charge properly again.
If that doesn't work, then maybe it's just the recharging circuit inside the mouse that's broken.
Jun 03, 2010 | Logitech Cordless Mouse
CE0682 logitech mouse
"Normal" batteries are 1.5 Volts per "Cell" However Ni-Cads, rechargeables, each "Cell" is only 1.2 Volts. So the rechargeables simply may not work... If they do work, then there is NO reason why not.
Feb 14, 2010 | Logitech Wireless Access Duo Optical...
I am getting a message that states that the waste ink tank for my HP H470 printer is almost full and that the printer will quit working when full. How do I change or empty this part and where do I find a...
You need to replace the ink service module BEFORE it gets completely full.
You can go to this web page for instructions:
Replacement of Ink Service Module
The part number is CB026-67043 for the Officejet H470 printer. You can order it from HP or check for availability from a local office supply store such as Staples or Office Max.
Here is the HP page to order:
HP H470 Ink Module
Thanks for using Fixya.
Jan 12, 2010 | HP Officejet H470 InkJet Printer
Where is the place to open the battery?
Number 1, there are 2 versions of the Logitech 880 Harmony:
You have either the (standard) 880 Harmony, or
the (PRO) 880 Harmony.
Number 2, BOTH versions require a BASE UNIT to RECHARGE the batteries.
I have located the user manual for the standard model here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=36tFryOj&p_li=&p_accessibility=&p_redirect=&p_tbl=9&p_id=5135&p_created=1152806515&p_olh=0
Alternately, the user manual for the "PRO" model is located here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=ZaqdtyOj&p_li=&p_accessibility=&p_redirect=&p_file_id=325891&p_tbl=9&p_id=3693&p_created=1208548871&p_olh=0
Hope this helps!
Dec 03, 2009 | Logitech Harmony 880 LCD Remote Control
Problem with LOGITECH S 510 cordless keyboard and mouse..
I have this same keyboard/mouse set and love/hate it when the batteries die. After you change the batteies, power on your pc, press & hold the connect button on the bottem of the keyboard first and then the connect button on the transmitter. Release them and wait for a few seconds. Repeat the same steps for the mouse.
When I have connection issue with this keyboard after new batteries, I have found most of the time the problem is the connection to the pc and/or batteries in wrong. Good Luck
C2Solutions
Aug 21, 2009 | Logitech S 510 (967555) (DH967555)...
Logitech Mouse asking me to change bateries while they are new
The rechargable batteries can start wearing out after some recharges. Try recharging the batteries or get a new set of batteries.
Jan 21, 2009 | Logitech Cordless Desktop EX110
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
