Question about Panasonic Kx-tg1031s Base W/ Answering System / Machine Kx-tg1031 Kxtg1031
Answering machine wont record call or show call on machine
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
Phone says " mailbox is full" but all recordings have been deleted and it has 0 recordings showing.
Without know what voice mail system you are talking about you cannot be helped.
Dec 06, 2012 | Lands Phones
Base shows an A instead of 0 for mailbox.
You have your answering machine set to the announce mode, where it plays an outgoing announcement but does not record incoming messages. You need to switch it to the record mode. Since you declined to specify the model of your AT&T 5.8GHz system, I can't tell you how to do that. Please refer to the manual for instructions.
Oct 27, 2010 | AT&T 5.8GHz Cordless Phone System with...
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Can not get messages on my answering machine, show the letter a
Your machine is set to "Announce" instead of "Answer" mode. The announce mode merely plays an outgoing message but does not record any incoming messages.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
Apr 22, 2009 | Vtech 5.8GHz Expandable Cordless Phone...
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Answering machine does not take messages
answering machine does not record message but keeps showing an A on screen
Jul 01, 2008 | Vtech i6772 Trio Cordless Phone
Panasonic Kx-tg1031s Base W/ Answering System / Machine Kx-tg1031 Kxtg1031 Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
