Dell optiplex gx270 memory
Sir i have dell optiplex gx270 mini tower computer i have 2 ram socket but now my 1 ram socket is working 2 ram socket is not working please help me how i fix 1 ram socket i have no money for repair i need help please help me
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
OK. The most probable cause is that one of your sticks of ram went bad. is your tower beeping when you install the ram? If so this is likely the problem. Good Day.
Posted on Feb 09, 2014
IB4G2008
  • 3587 Answers
SOURCE: Dell Optiplex GX270 Dual Channel DDR Feature
1 and 3
Posted on Mar 28, 2008
  • 46 Answers
SOURCE: I have two dell computers,
even though the memory stick sizes are the same, and the speed, there are other differences between memory types, such as parity/non parity, 2x32, 16x4 etc. more than likely, the speed of the memory sticks are different. the easiest fix for this is put the slower memory sticks in bank0 and bank1 (logical numbering used) and then the faster memory sticks in bank3 and bank4. this will cause the faster memory sticks to run at the speed of the slower memory sticks. If your sticks are parity and non-parity mix, then you will probably not be able to combine them.
Posted on Sep 26, 2008
Geekman
  • 32281 Answers
SOURCE: i cant find vista drivers for dell optiplex gx270 pc
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on May 02, 2009
blubaustin
  • 242 Answers
SOURCE: Sound card driver
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Dell-Optiplex-GX270-Creative-Audio-Driver.shtml
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Pc doesn't start properly, and displays a 1 & 3 on the front panel
Memory modules are detected, but a memory configuration or compatibility error exists.
May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Upgrade processor, unknown socket type.
Here I have found the technical specifications for this system, but for informational purposes it is pentium 4 and celeron 478pin intel only. http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
Oct 30, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
I have a Dell Optiplex GX270 running on windows XP pro. It has 2MB RAM and 80GB hard disc drive. When I checked to see if I could run Windows Vista Ultimate, the checker said I could, but might need to...
You'll need to have at least the following specs to run vista comfortable; 1 or 2 Ghz processor 1 or 2 GB RAM Video : AGP with 256mb or more cache Yoy might also have to consider changing your power supply.
Aug 13, 2009 | Dell Optiplex GX270
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
