Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Specification for SG7006 RESISTOR. The sg7006 open now
I have the same issue and cannot locate a replacement
Posted on Nov 24, 2014
What is sg7006 and how does it function in a sharp dpa-286ap power supply
You need to tell us where you are seeing that reference. Is it on a schematic or PCB? If it is on a PCB can you send a pic of it with a mark showing where it is.
Jul 16, 2017 | Sharp Televison & Video
What is an open zone and how do I fix it
an open zone is a detection zone that has a broken or loose wire in which the end of line resistor is not being seen from the panel.
each zone wire loop is constantly monitored using a resistor at the very end. this resistor is a specific value and is usually different for each brand of system. the resistor is either attached to the 2 wires at the end, or more commonly installed at the last device on that loop - again across the 2 wires.
as long as the panel can "see" the resistor there, the zone is normal.
if the 2 wires are shorted together, the zone is in alarm.
if either of the wires are broken, the zone goes into an "open" condition, meaning the circuit is open and the resistor can no longer be "seen".
fixing the open circuit involves using an ohm meter to read the resistance of the wiring and tracing the wiring from one end to the other to find the "broken" wire or loose connection.
it is not an incredibly hard process, but does take some skill. if you are not handy with an electrical meter, calling someone who is would be your best bet.
May 17, 2014 | Mace 80355 Wireless Home Security System
My KICKER amp KX200.2 has a resistor blown out it is R17 i will like to know the specific resistance so i can replace it
If you look closely at the color bands on the resistor. That will tell you what resistor you need to replace. All resistors are standardized color coded. You can find out the resistance online. Hope this helps.
Aug 14, 2011 | Car Audio & Video
The Heater Blower fan on our 1999 Tahoe only blows on Hi whereas a week ago it was functioning on all settings from low to high. Is thetre a specific fuse for the low blower fan settings?
Hello Go west.
No specific fuse I am afraid.
What you will find is a burned out blower motor resistor.
This resistor is mounted beside the blower motor just above the passengers feet under the dash.
Two small screws hold it in place. Easy to do. You may need to remove a hush panel to see it.
The resistor should be available at your favorite auto supply or at the dealer.
Thank you for using FixYa.
KL
Nov 15, 2010 | 1999 Chevrolet Tahoe
The unit will not turn on (Lowrance M68-C)
hey Jv,, Unless you have all the electrical specifications for each/all the circuits, etc..etc.. I doubt there is a chance you can.. .
Lowrance Service Repair Centers
Jun 27, 2017 | Lowrance M68C GPS Receiver
Mp3
The problem is that a CD has a stereo signal and the Marshall is mono.
You could make a simple mixer cable with resistors as a completed cable is not something you will find easily.
Take three 1K resistors joined at one end and connect the open ends of those one each to the three terminals of a stereo plug that fits you CD player.
Connect a mono plug and cable with "hot" to the joined connection of those resistors. Connect the ground shield of that cable to the barrel connection of the stereo plug that one of the resistros is also connected.
NOTE: if you use the "line" output of the CD player, then use 10K ohm resistors instead of 1K.
May 06, 2010 | Marshall 15 Watt Guitar Amp
2000 olds Intrigue gx
The key security uses a series of specific resistors values one appears in the run position and the other in the start position of the key. These resistor values are not of standard values. Some times when a tech installs a remote start they measure the resistor values from the original ignition key and try to pair a set of resistors to match. If they are close the system will work most of the time. However, hot and cold temps may make them drift so the MCU will not accept them. Also these external resistors run through relays of the remote car starter, if the contacts get dirty this will also change the resistor values. Best place to look for answers is with a remote car starter book about defeating the key security for remote start.
Oct 19, 2008 | 2000 Oldsmobile Intrigue
Picture looks like it is in 3D
Yes you need to replace both convergence ICs. They are both STK392-150 you will also need to replace the 6 feed resistors. You will need ( two ) 1.8 ohm 1watt metal film resistors.
( one) 3.3 ohm 1watt, ( 0ne) 2.7 ohm 1watt, ( one) 4.7 ohm 1 watt, and ( one ) 2.2 ohm 1watt . The resistors are all 1 watt metal film resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures, plus free tech support.
http://servicemanuals.vstore.ca/
Jul 30, 2008 | Hitachi 46F500 46" Rear Projection...
Manual convergence -service mode
you have some resistors that are still open . If the ICs go a resistor or two usually go open and you cant always tell unless you remove 1 leg out of circuit and check that the resistance is within 5% of the rated resistance. Trying to adjust it by the service menu will only place extra strain on the new ICs and they will blow on you. The resistors are located right next to the ICs there are about 8 of them all I dentical. Very easy to spot.
Mar 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
