Question about Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Need heat element for HMKJ-8A popcorn maker - Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Need heating element for HMKJ8a popcorn maker
Here is the link to Cretors distributors, but they do not make a HMKJ8a model. http://www.cretors.com/dealers.asp?i=16
I do not know who makes it, and a web search did not find anything. Please double check your popper model.
Feb 09, 2014 | Cretors Antique Goldrush Popcorn Maker
When plugged in, only the light works
its done...the element has blown and overloaded the motor....dont brother fixing it.
Dec 03, 2013 | Kitchen Appliances - Others
How and /or where to get the heating element
Any concessions Distributor will have access to cretors Parts. http://www.cretors.com/dealers.asp?i=16
You should talk with there service department first, The heating Element is always the last reason for a kettle to stop heating. Look at wires, thermostat, switches, and plug connectors first.
Jun 06, 2013 | Cretors Goldrush Popcorn Maker
After clening the kettle it blows breakers
You got the Heat element and or thermostat wet. Open the kettle to expose the electronics and let it dry for days. try again it might dry out.
Or you will need to replace the heat element, thermostat, and probably the wires. if it hasn't dried out by now.
Dec 26, 2012 | Paragon 1911-8 Popcorn Maker
Need to hook up wire for the element in the kettle of my GR6A1X -XX -X
Here is the wiring diagram for that model. Black(hot) wire to empty side of thermostat, red(indicator lamp) wire is doubled to the wire that goes to heat element, and the white wire is attached to far end of heat element.
Dec 13, 2012 | Cretors Goldrush Popcorn Maker
Will not pop the popcorn. The motor works, just will not heat up
Not familiar with the model but my best guess would be it needs a new heating element.
Oct 15, 2011 | Nostalgia Electrics CCP-200 Popcorn Maker
Echols 490 heating element ??????
call janet at Echols parts 573-734-2210
Jan 27, 2010 | Cretors Goldrush Popcorn Maker
Heating Element stopped working
remove the heat element cover attached to the element will be a thermal fuse it looks like a silver tube with a flat end and, a pointed end; remove and, replace the fuse; radio shack sells the fuse
Aug 28, 2009 | West Bend 82306 Stir Crazy® Popcorn...
Kettle does not get hot enough
Those aren't part numbers for a Cretors popper. Must be some other brand.
Jun 13, 2009 | Cretors Antique Goldrush Popcorn Maker
Heating
most likely the thermal fuse blew... Ohm it out and if its open then replace it. Take yours off, take it to your local Radio Shack
Aug 22, 2007 | Nostalgia Electrics KPM-508 Popcorn Maker
Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
37 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Coss
Ted Maxwell
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
