Question about Fagor Dishwashers
Program fault We are unable to select programs 4 and 5 however programs 1,2,and 3 work. No fault is indicated, either bleeps or F numbers. The time remaining window only lights up for the first three programs. All the progams were working until a few days ago.
SOURCE: Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Posted on Nov 11, 2008
SOURCE: G879 Miele dishwasher does not startup
I found the solution by phoning Miele. You just have to reset as follows: switch on with program 2 and 3 pushed in. Then push top solo twice. Switch off and on again. The Miele is ready to go.
Posted on May 07, 2009
SOURCE: When switched on the pumpbutton stays red and the
Thanks to a manual that was sent to me I understould I had to press the button P for a long time, that resets the machine. Thanks for your service! Carolijn
Posted on Nov 24, 2009
SOURCE: dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Posted on Jan 23, 2010
SOURCE: Just installed Hotpoint Dishwasher model LFT 114 uk
I'm having exactly the same problem, was this ever resolved?
Posted on May 10, 2010
What does error code E7 indicate on a bush dishwasher
E7 The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
For an E7 fault the PCB has to be reset:
1. With the door open, turn the appliance ‘On’
2. Within 3 secs, push the program selection button ‘P’ 4 times
The test program has been selected if ‘Soak’ and ‘Strong’ LEDs are flashing. (This combination represents the test program for appliances that have a flow meter.
1. If the above LEDs do not flash after carrying out the above procedure, then switch appliance ‘Off’ and repeat process again
Once the above test has been activated and the LEDs are illuminated then:
2. Push the program selection button ‘P’ once to select the version “without flow meter”
bullet Check that the ‘Soak’ LED is ‘Off’ and the ‘Strong’ LED is ‘Flashing’
To complete the procedure:
1. Ensure appliance is switched ‘Off’
2. Wait for approx. 10 to 15 secs
3. Switch the appliance back ‘On’
4. Select the SOAK program to test
Nov 02, 2015 | Dishwashers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
May 09, 2014 | Frigidaire Dryers
I have a ET100C and the lights will only stay on for a few seconds in both manual and auto modes
Before you attempt any reprogramming, you might be better served by performing a RESET on the clock. TO RESET TIME SWITCH COMPLETELY: Press the recessed RESET switch for five seconds to remove all eight available events and to reset time of day clock to 12:00 A.M.
After resetting, try reprogramming again. The procedure below is copied from the manual (which can be downloaded here):
TO MANUALLY TURN ON OR OFF: Program Selector switch must be in RUN position. In AUTO or MANUAL Press ON/OFF button. Display indicates load is either on or off.
TO SET TIME: Slide Program Selector switch to TIME SET. Press HOUR and
MINUTE buttons individually to select current time of day. Note that clock is a 12 hour AM/PM repeating clock.
TO SET OR CHANGE PROGRAMMED SET POINTS: Select PROGRAM mode with Program Selector. Note that the event display shows Event #1. There are eight possible programmed events. Four ON and four OFF which are programmed alternately. All available events need not be used.
Press the HOUR and MINUTE buttons separately to program the first ON time
desired. Note the ON indicator (OFF in the next step) will only be displayed after the hour has been selected unless an ON time was previously entered.
Press EVENT button. The display now shows the next Event #2. Press HOUR and MINUTE buttons separately to select first OFF time or Event #2.
Press EVENT button to select Event #3. This is the second ON time. Program the ON time by pressing the HOUR and MINUTE buttons. Repeat this procedure for up to 4 ON and 4 OFF times (8 Events) as required. Return Program Selector switch to RUN Position. Be sure Manual/Auto switch is in the AUTO position.
TO OVERRIDE PROGRAM: Program can be overridden at any time by selecting the MANUAL position. Program set times will be maintained but will not operate the controlled load(s) automatically.
TO CHANGE OR DELETE PROGRAM SET POINTS: Place Program Selector switch into PROGRAM mode. Press EVENT button to step through the eight possible events. Note that the times which have been programmed will be displayed or 0:00 will be displayed if no set point has been entered. To change an event time, press the HOUR and/or MINUTE buttons to change the time currently in the program to the new time desired. Press EVENT button to proceed to next programmed event. To remove a programmed Event: Press the ON/OFF button two times. When this is done, the display will show 0:00 and the event number.
I hope this helps & good luck!
Nov 16, 2011 | Intermatic ET100C Energy Controls -...
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
I'm trying to set up the TV channels for the View Sonic 2750. I'm unable to program channels 3 & 4 to allow the cable converter box to work. The cable channels start at 181 and stop at 90 the air...
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Oct 17, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at macmarkus@live.ca and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
Dishwasher wont complete program 1 2 or 3
Thanks Steve
Dec 18, 2008 | Dishwashers
Dishwashers Logo
14 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
matt
matt
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
