Question about Home Security
Heat glo fireplace - Home Security
5 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: My heat & glo fireplace
There could be a couple of different things wrong. Either the gas valve is bad, or the control board that opens the gas valve is bad. When working on gas lines and valves it is a lot safer for you and your family to call and have a trained repairman.
Posted on Nov 02, 2010
heatman101
  • 43501 Answers
SOURCE: My Heat-N-Glo fireplace has a
The ignitor may not be getting gas and the flame is not lighting so the ignitor shuts back off....
Bleed the gas line and make sure that you are getting gas to the pilot...
If the flame is lighting and it will not stay lit, then....
The first thing I would do is to take everything apart and vacuum and blow out the pilot burner, and the main burner. Also blow out everything around the burners and manifold with compressed air....
I think that the flame is not burning right and it is triggering the O2 sensor and that is what is shutting the burner back off.
If all of that does not work then you will need to replace the O2 sensor or the thermocouple...
heatman101
Posted on Nov 25, 2010
  • 4736 Answers
SOURCE: hello, My heat n glo fireplace
Yes, just a couple of thoughts and questions. When you replaced the batteries, how many batteries did you replace? If it wasn't more than 2, you have 4 more AA Batteries to replace in the receiver (black box that beeps) behind the louvered flip down door. If you did replace those, recheck them to make sure they all facing the proper direction. One battery out of place, will throw the whole system off. In addition, sometimes the Slide Switch on the front of the Receiver (black box) can be a little finicky. It may appear to be in the REMOTE position, when in fact it isn't. Gently moving it one way or the other will allow you to feel it go into place.
It would also be wise to check the two wiring connections, at the receiver box and the control valve terminals to make sure they are tight. The wires to the control valve terminal should be on the TH & TPH terminals. Also, make sure the wires haven't been grounded out due to wear and are touching some metal part of the firebox.
And last, but not least, your Heat-n-Glo fireplace has it's own ON/REMOTE/OFF rocker switch. Has it been moved to the wrong position? If it has, it's overriding the remote control. Depending on who installed this fireplace, the may have just wired the remote to the wrong switch position. So, try using the hand-held remote in all three positions, until you find the right one.
If all else fails, contact Sky Tech Systems, Technical Service Dept 888-672-8929. They are great folks to work with.
Posted on Apr 13, 2011
  • 236 Answers
SOURCE: Heat n Glo gas fireplace pilot doe not stay lit
http://www.heatnglo.com/Owner-Resources/Troubleshooting-and-FAQs.aspx
Posted on Oct 17, 2015
How to replace the thermocouple
Not a user procedure. All work on gas appliances of this type must be undertaken by a qualified gas fitter or service engineer. Why? BOOOOM!
Dec 01, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
I have a heat & Glo XLR Plus. This is the first time I have used it but when I turn it on, the flame burns for around 30 sces then goes out. Then after about 30 secs it comes back on.. then off and so...
On your hand held remote [check your remote's owners manual], there is a mode setting for thermostat. This allows your remote to act as the thermostat for the room. It is in this mode and the temperature is set close to the current room temperature. Turn this mode off. Do not use this mode. Obviously you do not have the required experience to use it. It will come on and off even when you are not home. Again, until you become a lot more familiar with the setting, turn it off.
Mar 08, 2015 | Heat and Glo GFK-160A Blower Kit for Heat...
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
Fireplace remote not working properly
Jim,
I'm not sure if you have found a solution to your problem yet, but if you would like to provide some additional information about your problem, I'd be happy to help.
If you are looking for a replacement, I have them available here: Smart Stat Remote for Heat-N-Glo.
Jan 01, 2013 | Skytech Smart Stat Fireplace Remote for...
Owners manual heat-n-glo smart-stat
Try searching through this:
http://www.heatnglo.com/Resources/Customer-Care/Installation-Manuals.aspx
Nov 11, 2012 | Skytech Smart Stat Fireplace Remote for...
I need operating instructions for a Royal Fireplace.
The following link is to the Owners manual for your wood burning, Heat & Glo, Royal Fireplace.
You can download and print the entire manual.
http://www.heatnglo.com/~/media/Files/Heat%20n%20Glo/Installation%20Manuals/4044_153.ashx
Hope this helps to get you safely up and burning.
Please let me know.
Mar 06, 2011 | Royal Heating & Cooling
Need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
