Question about Whirlpool Dryers
Red light on whirlpool condenser dryer saying clean heat exchanger. How do I clean it ? When I plug in & choose start it ' blows ' the electric ?
  • 1073 Answers
SOURCE: whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Posted on Apr 12, 2008
  • 7 Answers
SOURCE: Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Posted on Aug 30, 2008
farfield
  • 462 Answers
SOURCE: electric whirlpool dryer not heating
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
SOURCE: electric whirlpool dryer turns & heats but does not dry
the flames on the dryer come on for a couple of minutes and then shut off then comes back on about 5 min. later,. the cloths don't get dry . this goes on the whole time the dryers running, take 2hours to dry a load of cloths
Posted on Jun 24, 2009
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
Why is warning lights on on my AZC6470 Whirlpool condenser dryer when i have cleaned heat exchanger/filter and emptied water container
Not trying to be a smartass but what does the manual say about the warning lights as in what do they refer to.
Oct 09, 2014 | Whirlpool Dryers
3 x Flashing Red Lights and 2 x Solid Green
Hey my friend, we have all done repairs and are sure of ourselves putting it back together right! But we are only Human. The plain fact that it ran yesterday if evidence enough. It's more than likely your problem. You did basically tore it limb from limb, LOL. just one more try?
Jan 18, 2013 | Whirlpool Dryers
My whirlpool condense dryer 6th sense the light keep flashing red saying clean filter, empty bottle and heater exchange I have done all that and it still won't work can you help please.
Have you tried unplugging it from the power source and then plugging it back in? This may prompt the mini computer inside the dryer to reset to the proper default settings. Best of luck!
Jan 15, 2013 | Dryers
My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
19 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
