Question about Sylvania 6615LCT 15 in. EDTV-Ready LCD Television
Sylvania 6615lct directtv code
I need to program my Direct TV remote
  • 8 Answers
SOURCE: I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Posted on Mar 29, 2009
SOURCE: codes to program tv to direct tv remote
try this
http://2getdtv.com/directv/remote_codes.html
Posted on Apr 06, 2009
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: can't program direct tv remote control to the tv
Try here:
http://www.twirp.com/en/index.php
Posted on May 23, 2009
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Posted on Aug 20, 2009
Sylvania tv codes
0038,0039,0030. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to may popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 28, 2013 | Televison & Video
Tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
I cant get my directtv remote to work with my sylvania LC321SS9, all the codes given by the directtv console failed to program it.
Log onto www.directtv.com and click on equiptment at the top righthand side of the page,then click on remotes,mid page on the right says "program your remote" just below that click on "look up instructions" scroll down to "program your Direct TV remote control" and click on it,click on the model# of your remote control,enter your TV brand in the box and just continue to follow the instructions. Good luck !
Jan 07, 2010 | Sylvania LC320SS8 32 in. LCD Television
I just installed direct tv and their remote wont let me change volume. if I use the tv remote I lose the programming. Need a code so the tv can be controlled by direct tv's remote.
Hi, post the direct TV remote # and the box model # so I can lookup the info for you. you probably already know directTVs remote programming is built into the menu (codes and all).
You did not mention if the DT remote powers the TV on or off?
post more info if you still need help and I'll try
Thanks
Eric
Sep 04, 2009 | Proscan 42LA45H 42 in. LCD TV
Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
May 05, 2009 | Insignia IS-LCDTV32 32 in. Television
enter 9911
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Cannot use the direct tv remote to control the volume, on / off, etc.
I have directTv and an olevia TV, and DirectTV remotes do not support Olevia
Jul 25, 2008 | Televison & Video
Cannot program Direct TV to Sylvania 32"LCD TV LC320SS8
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
here are the code for your tv: Sylvania 10054, 10030, 10171
Dec 01, 2007 | One For All URC-3021 Remote Control
Trying to program my DIrect TV remote to work my ILO TV
i have two tvs 1 is an Ilo and the other is a Sylvania. the code for sylvania works for both tvs on the Direct Tv Remote Hope this all helps and here is the code. 10171, there are also two other codes for this tv and they are 10054, and 10030. Have a good day and happy watching.
Darklove_420
Nov 10, 2007 | One For All URC-3021 Remote Control
Sylvania 6615LCT 15 in. EDTV-Ready LCD Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
