Question about Epson Office Equipment & Supplies
Epson printer manual
I would like to scan photos and documents from my recently purchased epson printer model # wf2530 into my hp pavilion 14 chromebook. As no manuals were furnished with either systems I have no idea how to do it. I am able to print wirelessly from the laptop to the printer with no trouble. But I can not do the reverse not because of technical problems but because I just don't know how. The chromebook laptop does not have windows.
SOURCE: Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Posted on Jan 29, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
Fixe_You
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
  • 133 Answers
SOURCE: Cannot print documents wirelessley from SX515W
in vista as with windows 7 you must tell the computer to connect to your printer in network preferences. It wont work untill it is told to connect!
Posted on Jan 01, 2010
SOURCE: ALTERNATE FOR EPSON PRINTER DRIVER STYLUS CX1500 FOR VISTA
Hi:
I can get the printer supported by using the Epson Stylus C45 Series (M) printer driver.
Works fine, but scanner does not.
Oz
Posted on Oct 27, 2010
How do I scan a document
Depending on the PC operating system you could download the instructions for how to scan from this site.
Scan HP Deskjet 3050 All in One Printer J610a HP Support
Aug 25, 2014 | HP DeskJet 3050A All-In-One Printer...
How do you scan a document using a pc?
The printer can be used for scanning without a computer in sense of the scanner offering a copying facility - in B+W or Colour just by pressing the appropriate button on the printer. However, for scanning via the computer, if you are using a Photo programme (like say Adobe Photoshop or virtually all such programmes) normally you will find under the FILE menu (when programme is open) that you should see a menu item on the drop down menu when you click on FILE something like IMPORT - and the Epson printer will be seen listed in the menu that pops up. If you click on that, the Epson scanner programme will start. Normally there is a simple mode but you can change that to the PRO (or may be called Advanced mode) when you can do things like PREVIEW - which will then scan the document or photo in the scanner - and you can in the PRO mode change such as the resolution, what type of documents and so forth. When the Preview runs, you will see the document appear after the quick scan in the main RH panel. You can use a select tool to select the bit you want to scan if not the whole - most into on this will be in their manual - which you should have on the CD that came with the printer. Anyway - always worth ensuring you have the latest drivers, etc. so go to this link on the Epson website, click on Scanner Driver and Scanner Utility and download and install. Whilst on the Epson website, download the manual for that model as it will answer many queries for you as regards printing and scanning. All such info and software for downloading is under SUPPORT area - you select the region in the World where you live, then search for your printer model. The Epson website will normally auto-detect your computer's operating system to ensure you get the right version of Printer Drivers, other software and so forth. If you have no Photo Programme as yet - get Faststone Image Viewer (free) as an excellent programme. http://www.faststone.org/FSViewerDownload.htm
Jun 25, 2014 | Epson Stylus Multifunction Inkjet Printer/...
My Epson Perfection V500 Photo won't scan any negatives. It scans them as photo's. I've removed the document mat, unlocked the lock, connected the cover cable and adjusted the software settings. I can't...
I don't know of any regular printer that scans negatives. Check your printer manual to see if it's designed to print negatives. You can get devices that will do that, but I'm not certain any regular printer will. If you don't have a manual you can look up your model online to find out more.
Oct 14, 2017 | Epson Perfection V500 Flatbed Scanner
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
I don't know how to scan a document to a file on my NX400 Print, Copy, Scan & Photo. I would appreciate a copy of the manual. Can you e-mail the copy to me?
I clicked on "Home Mode" then followed the instructions. Nice if your doing many photos. But not very simple when you want to scan to a document file. The other scanner that I had (not compatible with Windows Vista) was very simple to use -- did not have to go to many windows a click on various items to get a simple scan. Maybe I should have purchase another brand of scanners.
Nov 15, 2008 | Epson Office Equipment & Supplies
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
