Question about Lexmark E120n Laser Printer
E120 error lights - Lexmark E120n Laser Printer
4 red lights on printer won't work
The printer operator panel has two buttons and sixlights (the Continue button is both a light and button). Lights indicate the status of the printer. Buttons are usedto continue or cancel the current print job. The lights are represented byReady/Data light, Toner Low/Replace PC Kit light, Load/Remove Paper light,Paper Jam light and Error light. Since you've mentioned that printer has 4 red lights,we would like to know which light is it. Please provide us more information. For further assistance, please contact LexmarkTechnical Support.
Jan 20, 2011 | Lexmark E120 Laser Printer
E120 Laser Printer: my Lexmark e120 printer doesn't printing at all, n...
You may need to replace your photoconductor unit. Part number 12026XW
May 17, 2010 | Lexmark E120 Laser Printer
I WAS PRINTING AND THE E120 STOPPED AMNT HERE IS AN ORANGE LIGHT. tHERE IS NOTHING IN THERE ARE FAR AS PAPER JAM AND THERE IS PLENTY OF TONER
You may need to replace your photo conductor unit part number 12026XW its the part that is in behind your toner cartridge it needs changing every 30,000 copies.
May 01, 2010 | Lexmark E120 Laser Printer
While printing, it stopped and orange (error) light went on. Coolers work, it has toner and paper, no paper stuck, everything looks normal. I restart power , but it is the same. printer model Lexmark...
You may still be able to do a printer selftest page.
Press the large button on the printer.
Look at the pages for
Toner
Imaging unit
The Imaging unit may be at end of life.
This is the drum unit and collects the waste toner.
Whilst you can just reset the drum counter (see user guide for this E120, it can lead to problems if you don;t replace the drum unit. I've seen E120 drum units packed full of waste toner, to the stage where they won't take any more, and it just spews all over the mechanism. It's a very small waste collector (but its also a very small printer, and relatively low capacity toner cartridges (1k, or 2k).
Remanufactured drum units for E120 can be found on the usual internet auction sites.
Mar 15, 2010 | Lexmark E120 Laser Printer
Error light is alway on on lexmark e120
Besides refilling the cartridge with toner there is a chip in it that you should change so the printer will know that a new cartridge is installed.
Jun 15, 2009 | Lexmark E120n Laser Printer
Charts not working
Your chart reader may be messed up on your E-series. Contact Raymarine and inform them of the problem.
Mar 06, 2009 | Navionics: Gold+ Chart Cartridge
Error light on
Could be drum unit (imaging unit) at end of life
Sep 04, 2008 | Lexmark E120n Laser Printer
Lexmark E 120
i DON"T HAVE THE CD AN I NE INSTALATION HAW I CAN DUED
Jan 12, 2008 | Lexmark E120n Laser Printer
Flashing error code
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 20, 2007 | Toshiba e-Studio120 Copier
Lexmark E120n Laser Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
