Question about la-z-boy.com
Cleaning fabric getting out stains
How to get blood out of carpet?
hi Connie.
Check out the instructions below.
  1. If the blood stain you're trying to remove is dry, go ahead and brush it with a steel brush to loosen the stain. ...
  2. Mix one teaspoon of hand dishwashing detergent with two cups of cold water.
  3. Take a clean, white cloth and dip it in the detergent solution you just mixed.
More items...
How to get Blood out of Carpet - Remove Blood Stains From Carpet ...
spotremoval.coit.com/how-to-get-blood-out-of-carpet
How do you remove blood stains?Follow These StepsWet the stain with cold water. If the stain is fresh and still wet, soak fabric in cold water immediately.Rub with soap. Rub the stain well with a bar of soap, lathering gently. ...Re-soak the stain with a pre-treatment stain remover. ...Dab on diluted ammonia. ...Launder fabric.How to Clean Blood Stains Video and Steps - Real Simplehttps://www.realsimple.com/home-organizing/cleaning/cleaning.../remove-blood-stainsSearch for: How do you remove blood stains?
or try this link.
How to get blood out of carpet Google Search
Nov 26, 2017 | Health & Beauty
How can I repair a bleach stain on a t-shirt
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Aug 06, 2014 | Clothing
Remove bleach stains
Apr 03, 2014 | Clothing
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Jan 20, 2014 | Miele Washing Machines
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
Do you need to put a cleaning agent on a fabric lounge before using the steam fo the Steam Matey
I would say no, if you have a specialised stain clean that area first. Start with warm soapy water and if that doesn't work use zippo lighter fluid on the stained a area to remove the stain. Zippo lighter fluid is great for removing stains as it is our alcohol. Always try any cleaning agent on an area of the lounge that if it makes the stain worse it won't ruin the lounge I.e under a cushion. When steam cleaning any fabric you should check the fabric specifications to see if its suitable for steam cleaning. Some fabrics like macrosuedes that have a backing on the fabric will delaminate when wet and ruin the fabric.
Aug 30, 2013 | Kitchen Appliances - Others
Kenmore 70 series, leaves browb lines on clothes. is there cleaning procedure for the washer?
It could be coming from your fabric softner. I know when I use liquid fabric softner I get oily looking stains on clothes. I no longer use liquid softner. I also use Dawn dish soap in my washer. I use Dawn instead of any other stain removers. Dawn dish soap works on everything.
Dec 02, 2010 | Kenmore Washing Machines
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
la-z-boy.com Logo
24 people viewed this question
Top la-z-boy.com Computers & Internet Experts
David Payne
David Payne
Are you a la-z-boy.com Computer and Internet Expert? Answer questions, earn points and help others
