Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Viper 5710v car wont remote start, flashes 7 times saying remote start error
  • 212 Answers
SOURCE: battery died in the remote and now car remote wont unlock security
try another battery. maybe that one is bad also. contact the security system manufacturer or a viper dealer. They will help You.
Posted on May 24, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
  • 306 Answers
SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Posted on Feb 08, 2010
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
  • 18 Answers
SOURCE: Change VIPER Responder One runtime
Actually the first solution may or may not be true. If whomever installed the remote starter "locked" the programming with a bitwriter, then you will need to take it back to someone with a bitwriter to unlock and change the setting. If it was not locked then you can change run times for that model yourself. You have choices of 12, 24 or 60 minutes. 12 is the factory setting (with a bitwriter you can choose in one minute increments). If your system is unlocked this is how you can change the runtime setting. It's a bit of a pain so you might want to write it down. There should be a small programming button attached to wires coming from the "brain". First, locate that button. 1. Turn ignition key on then back off. 2. Quickly push and HOLD the programming button. If the horn was hooked up to the remote start system, it should honk once. (If it wasn't you'll have to look for a small led status light on the brain that should flash once) To change runtime, keep holding the button down till the horn honks twice (or the led flashes twice). 3. Release button after horn honks twice (or led flashes twice.) You are now in menu two where runtime is set. 4. Within 10 seconds, press and release the programming button two times. Now push and HOLD the programming button. You are now on feature two of menu two (runtime options). While still holding the programming button in, press the remote start button on the fob the number of times that corresponds with the run time you want. once = 12 minutes, twice = 24 minutes and three times equals 60 minutes. After selection has been made release programming button. The programming sequence will be cancelled if any of the following occur: Ignition is turned on or programming button is pressed too many times or more than 25 seconds elapses between steps. Like I said, it is a pain to do manually and there is a possibility you could mess up other settings if you get it wrong. But this is what the install manual states if you want to give it a go. Good luck!
Posted on Feb 07, 2011
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have the viper 5701 on a bmw 540i and the alarm works so does the keyless but the remote start does not work, the park lights flash 7 times and gives an error code,what can cause this?
The flashing parking lights signal a shutdown diagnostic. There is a nuetral safety switch under the dash. It's a toggle switch that needs to be in the on position. Also, the hood pin needs to be making contact with the hood when the hood is closed.
Jun 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2001 jeep grand cherokee /viper 5101 rs with keyless entry all wires are hooked up properly as far as im concerned but remote start will not activate i have a 7 flash diagnostic code
I'd say the easiest thing would be to stop being a lazy tw@ and get into the vehicle with a key as normal. Come on, lose some wait...
Mar 11, 2011 | Remote Start System
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
Remote start will not work, it keeps giving error message of 8 parking light flashes which say the neutral safety switch isn't grounded, but it is. Any ideas?
is there a toggle that was installed inline? If the unit doesnt see a ground on the neutral afety switch wire, the remote starter will not crank.
Aug 10, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program viper 5701 remote
Unlock doors
Key out of IGN
Test unit
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
64 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
