Hp mini 110 keyboard doesn't have backlit.. how can I possibly turn it on?
  • polytek Feb 09, 2014
    Hi Gay Mendez, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • 1,087 Answers
I am not sure if you are saying the keyboard is not lit, or the screen isn't? If the screen, If the battery can be removed, try removing it, disconnect from AC adapter too, and leave it there for 30 seconds. After doing that, connect it to the AC adapter only and turn it on.
If it works, shutdown, connect the battery back and try to turn it on again. If it works, lucky you, your battery is not bricked. Otherwise you may have to get a new one, or use the equipment with AC adapter only.
Posted on Feb 09, 2014
4 Suggested Answers
Steventheone
  • 94 Answers
SOURCE: why i am use the bluetooth in my hp 110 mini ?
You are not able to use the bluetooth.
Because unfortunately the notebook is not shiped with the bluetooth device.
Check out the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764349&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Jun 13, 2010
  • 182 Answers
SOURCE: how to remove the keyboard of a HP Mini 110 3130sv
Removing the Damaged Keyboard
1. Enusre the laptop is fully powered off, unplugged laptop ac adapter from the wall, and the battery taken out.
2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard for HP Mini 110-3130sv displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
3. Remove those screws with a T-8 or Phillips screwdriver.
4. Turn the laptop back over and open it up. Check and see if the HP laptop keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, ribbon cable to the system board at the bottom.
7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
8. Carefully remove the data cable. Now the whole HP Mini 110-3130sv replacement keyboard should be free.
Replacing the keyboard.
1. Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
2. Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
3. Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
4. Refasten the keyboard in place at the top.
5. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
6. Turn the laptop over and replace all of the keyboard screws.
7. Finally, put the battery back in and power on the laptop. If all has gone well, the HP Mini 110-3130sv Keyboard should be functioning like brand new.
Posted on Sep 01, 2011
  • 62 Answers
SOURCE: unlock current password for hp mini 110
The experience that I forgot windows password on Hp happenedto me a few weeks ago.
My friend Acheson who is an IT engineer recommended meto take use of Windows Password Reset
,which is very smart and just take me a short time to reset a newly password.
I think it can help you too.
Posted on Jun 20, 2012
My keyboard will of work on my HP 110-3100 mini. External keyboard will not work as well
you computer must have turned off your "default" key board.try this: goto control panel, find "input devices" and turn on your original keyboard to "default" and wa-la! hope this helped. input devices might be under "keyboard"
Jul 20, 2013 | Computers & Internet
I can't working with keyboard HP mini 110 RN
Buy a new keyboard and make the substitution
Jun 21, 2012 | HP Mini 110-1037NR Netbook
How to remove the keyboard of a HP Mini 110 3130sv
Sep 01, 2011 | HEWLETT-PACKARD Mini 110-1031NR Netbook
When i turn on my dell 110 mini the light goes from white to orange and stays there the screen doeset boot or anything
Remove battery, open the access panel on the bottom carefully remove the ram sticks. Put them safely on a piece of paper so that a static charge doesn't ruin them, also touch something metal before you try and remove. If your computer doesn't beep at all when you power it back on your CPU, GPU, or MB are bad. If it beeps then there is still hope.
Jun 10, 2011 | HP Mini 110-1037NR Netbook
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Apr 12, 2011 | HP Computers & Internet
I have a HP Mini 110-1116NR PC it wont turn on No lights or any thing
Possibilities are inmense, first make sure that your power supply is working, remember that its what charge the whole thing up. if power supply is not giving the right voltage the the lithium battery is not charging. You may have to take it to your local computer shop yo check it
Dec 16, 2010 | HP Mini 1000 Netbook
HP MINI keyboard letters doesn't want to work
the letters of n, b and six, seven of my HP Mini 110 keyboard would not work, what should i do?
Oct 28, 2010 | HP D8597A Keyboard
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
