Question about Dell OptiPlex GX110 PC Desktop
Installing a network card
I'm having some trouble installing my Linksys WMP54G. I removed the expansion bay and got the filler bracket thing out, but I can't get my WiFi card in - it won't go down.
I've had this type of trouble before with RAM, and there was a trick to it. What's the trick here?
Any and all suggestions appreciated.
  • jacob-s Oct 26, 2007
    Hmm... there's 3 "teeth" (2 notches) in the wifi card, and only two in the expansion slot. Around one that they have in common, it's pretty tight. It looks light it might be a millimeter or two off. But it goes down past this.
    The place where only the card has a notch looks like it'd fit right in.
    Unless this is the wrong kind of card?
    Welp, I got it with some fiddling. It works now. Thanks for helping.
  • 328 Answers
Make sure the slots line up perfectly. It should be pushed firmly and evenly into the slot. Make sure that the metal bracket is not in the way or hitting anything else.
Posted on Oct 26, 2007
  • Lyle Siemens
    Lyle Siemens Oct 26, 2007
    The slot should line up perfectly. If you have more card than slot, it will not fit. It is possible for a smaller card to fit in a larger slot though but not the other way around. Also make sure that you are not trying to put an AGP card into a PC-i slot or vise versa.
SOURCE:
I look for driver
Click below to open the support page for this network adapter:
Linksys by Cisco - WMP54G Support
May 30, 2009 | Dell Computers & Internet
Installed wireless adapter to windows 2000 computer it still says offline
After installing the wireless adapter, did you check if the software that manages the Linksys adapter picks up any signal or network that you can connect to?
Apr 09, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Linksys wireless-g wmp54g cannot access internet
Hii
Solution- For windows XP
#1--On your computer in the right lower corner you will a green icon for linksys adaptor --
Right click on linksys icon- select option "use windows wireless configurastion --- Select Yes ---
Green box turn Grey --
#2-- Start - Control Panel-Network Connections ---
Rigfht Click on wireless network connection- Selct View Available wireless network - Here you can see your network --
Mar 29, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Need XP Driver for Linksys wireless adapter, Model:WMP54G I have downloaded driver from linksys site (Ver 4 and 4.1) it is not working. I think i need earlier driver version. Can u help me? Serial no of my...
Uninstall the driver you are using, and install the one from here:
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Linksys-Wireless-G-PCI-WMP54G-101.shtml
That'll work in XP and if you want to see if a newer version is available that is compatible with XP, you can Update Driver from the Device Manager and that'll find and install the latest one that still has XP support.
Hope this helps
Chris (ziraffa)
Dec 27, 2008 | Computers & Internet
Linksys wireless adapter not being recognized by 2wire wireless
1. uninstall the WLAN monitor from add/remove programs.
2. restart computer. it should say "found new hardware" (for the WMP54GS)
3. insert the installation CD for the WMP54G, but make sure that you do not install the WLAN monitor. just install the drivers for the card.
Then let windows control the wireless.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 13, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
How did you fix wmp54g Linksys PCI network adapter driver code 10 problem? I googled on this and got tired. Everyone poses this question, but there was no appropriate solution that works around this...
Try this first:
Shutdown PC. Take adapter out. Boot. Install software. Shutdown PC. Put adapter back in. Boot.
If that doesn't work try this:
Shut down the pc before removing or installing adapter.Uninstall device, uninstall software, remove all oem*.inf and oem*.pnf for Linksys products (searched by keyword "Linksys"). Also one of Microsoft drivers was provided for this so I've decided to change its name. After reboot and normal installation procedure everything works ok.
To delete the necessary files go to www.linksys.com/easy and use Netcheck. Easy because this great tool will automatically set-up and install the device for you.
Nov 25, 2008 | Computers & Internet
My Wireless-G WMP54G card keeps Installing Dell Drivers
I hate to say this, but on Dec. 26, 2008, I called Linksys and they said that they don't make a PCI wireless adapter that works with sp3. Mine just rebooted the computer incessantly.
Nov 09, 2008 | Linksys Wireless-G WMP54G 802.11g/b
Need pci Filler For WMP54G OptiPlex GX150 PC Desktop
By PCI Filler I Mean The Metal Peice That Screws onto the card that screw it to the case as the Dell OptiPlex GX150
Is Very Small And The Pci Card Slot Covers Are Different Size Than A Full Size Case
Nov 05, 2008 | Dell OptiPlex GX150 PC Desktop
Dell OptiPlex GX110 PC Desktop Logo
48 people viewed this question
Clive
Clive
Alun Cox
