Question about Toshiba SD-K510 DVD Player
I need to program a universal remote for a Toshiba SD-K510.
Don't have the original remote. I need a code to put into the universal. Where can I get the code?
    New Friend:
It is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Posted on Dec 22, 2009
SOURCE:
Need codes for he universal remote to program to Toshiba DVD player SD-1800
Use the code search provision of your universal remote to seek a suitable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 03, 2016 | Toshiba SD-1800 DVD Player
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
Toshiba sd-k510 disc error
Have you tried several discs?If so,then your DVD player may need servicing and a probable lens replacement.
Thanks!
Jan 04, 2012 | Toshiba SD-K510 DVD Player
Purchased an RCA universal remote (RCRH02B) and the codes listed in instructions don't work. After programing (or trying) the device with all the codes individually, the TV will turn on and off,...
Consider that you may have a bad remote. You never mentioned why you bought a new remote. Did the original remote quit working? If so, the problem may be with the TV.
Jan 04, 2018 | Toshiba 13A24 13" TV
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
How can i change toshiba sd-k510 dvd video player region free?
i need a region code for toshiba dvd player sd-k510
Jun 01, 2008 | Toshiba SD-K510 DVD Player
Toshiba SD-K510 DVD Player Logo
658 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
