Question about Monte Cristo Games 7 Sins
7 sins requires 3.4.71.19;3002 - Monte Cristo Games 7 Sins
Hi when I solve my problem sin inverse the calculator show math error
Try using the arcsin function (usually SHIFT SIN or 2nd SIN, depending on the make and model) instead of SIN1/x.
If you require further assistance, please repost your question, including the make and model of your calculator, as well as the exact key sequence you're using.
Nov 12, 2016 | Office Equipment & Supplies
How to type sin theta and cosine theta in casio fx-85MS
Since this calculator cannot perform symbolic manipulations (algebra) you never need to type in sin(theta) or cos(theta). To calculate the sine of an angle (whatever the name of the angle may be) just press the sin key followed by an angle value and the function will be calculated. same thing with any other trigonometric function.
Make sure that the angle units is set to the unit required by your calculation: degree, radian, or grad.
Jul 16, 2014 | Office Equipment & Supplies
How do you calculate sec174?
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
Feb 05, 2013 | Sharp EL531 Scientific Calculator
Cant find the arc or inverse button
The trigonometric function [SIN],[COS] and [TAN] have inverse functions arc-sine, arc-cosine, and arc-tangent which are also implemented on scientific calculators. To access the inverse trigonometric functions you use the sequences [SHIFT][SIN], [SHIFT][COS] and [SHIFT][TAN]. The functions are marked on the body of the calculator as [SIN^-1], [COS^-1] and [TAN^-1].
When you use these functions, make sure that the angle unit is correctly set (as required by the problem you are solving) because the angle values returned are in the same unit as the one set.
Jan 15, 2011 | Casio FX-115ES Scientific Calculator
Differentiate each of the following w.r.t.x; 29.sin2xsinx
Use the rule for differentiating products of functions: ()' signifies derivative
(29*sin(2X)*sin(X))'= (29)'*sin(2X)*sin(X) +29* (sin(2X))'*sin(X) +29*sin(2X)*(sin(X))'
But
  1. (29)'=0 derivative of a constant is zero
  2. (sin(2X))'=cos(2X)*(2X)'=2*cos(2X)
  3. (sin(X))'=cos(X)
Result is
(29*sin(2X)*sin(X))'= 29*2*cos(2X)*sin(X)+29*sin(2X)*cos(X)
You could also have cast your formula in the form
sin(2X)*sin(X)= 1/2[ cos(2X-X)-cos(2X+X)]=1/2[cos(X)-cos(3X)]
then calculated the derivative of
29/2*[cos(X)-cos(3X)]
which is
29/2*[-si(X) +3*sin(3X)]
The challenge for you is to prove that the two forms are equivalent
29*2*cos(2X)*sin(X)+29*sin(2X)*cos(X)=29/2*[-si(X) +3*sin(3X)]
Jun 21, 2010 | Vivendi Excel@ Mathematics Study Skills...
1 + sinx = 2cos^2x
Hii..this can be done as follow
cos^2 x = 1 - sin^2 x--------(1)
2cos^2 x=1+ sin x
2cos^2 x - sin x -1=0
Substituting formula (1)
2(1 - sin^2 x) - sin x - 1 = 0
2sin^2 x + sin x - 1 = 0
Factor this
(2 sin x - 1)(sin x +1) = 0
2 sin x - 1 = 0 or sin x +1 = 0
sin x = 1, and sin x = -1
Apr 26, 2010 | SoftMath Algebrator - Algebra Homework...
How to use the SIN botton EX: 25 x SIN(65)
Before starting to enter the angle measure to calculate the value of a trigonometric function (sine, cosine, tangent) you must make sure that the current angle unit (degree, radian, grad) the calculator is configured to be using is the same that your problem requires. For instance, if you are solving a problem in which the angles are given in degrees you must verify that the calculator is configured to work in degrees.
When calculator is turned on, the angle unit is reset to degrees, but just to make sure it still is, look at the display: It should show the indicator DEG. If the display indicator is not DEG press the key [DRG] once or twice until you see the DEG on the screen.
The angle unit being taken care of, we turn to the actual calculation
Usually, to calculate the sine of an angle, you enter the angle value, press the [SIN] key and hit [=]. As you can see the sine function eats the number stored in its current register and calculates its sine.
To make sure that the calculator is taking the sine of 65 and not of 25*65, I would enter the calculation as follows
[65 [SIN] [*] 25 [=] : the result should be 22.65769468
or
25[*][ ( ] 65 [SIN] [ ) ] [=]
In the last key sequence, the use of parentheses forces the calculator to pause all previous calculations and wait for the closing right parenthesis. When the right parenthesis is entered, the calculator takes care of the contents of the parentheses first, then resumes the operations entered before the parentheses.
Importance of checking the angle unit before a calculation
Let us perform the calculation with angle unit
  1. in degrees : 25* sin(65) = 22.65769468
  2. in radians : 25 *sin(65) = 20.67071699
As you can see, the two values are not very far apart and since you are expecting a value that does not exceed 25 you might want to check your result.
Hope it helps.
Thank you for rating this solution
Dec 12, 2009 | Texas Instruments TI-30XA Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
7 Sins game wont load new game
Hi there did the system requirements of the game meet your system?... if yes try to ask your local computer shop to try it on their computer then you'll see if it is defected or not...
Jan 03, 2009 | Atari 7 Sins for Windows
Trig Identities
Change csc to 1/sin. Find a common denominator and add the two left terms.
1/sin - sin = (1 -sin^2)/sin. Rewrite formula
(1 - sin^2)/sin = cos^2/sin Divide out the /sin.
1 - sin^2 = cos^2 Rearange.
1 = cos^2 + sin^2 Yes, that's true. It's like the Pythagorean formula.
May 22, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Video Game Consoles & Games Logo
60 people viewed this question
Top Monte Cristo Games Video Game Consoles & Games Experts
James Wishart
Are you a Monte Cristo Games Video Game Console and Game Expert? Answer questions, earn points and help others
