Question about Honda Maxus Prosumer MX5223 Pressure Washer
Fuses every time I switch it on
Every time I switch on the pressure washes, it blows my mains fuse
    Sergeant:
  • 415 Answers
The load is too big for the circuit you are trying to run it on.
Posted on Mar 06, 2014
Kymco k pipe has no electrics after washing it is blowing new fuses
Hi, Lynn if you have access to compressed air you need to blow out the excess moisture in the fuse panel and all electrical components that may have gotten wet otherwise you will just have to wait until everything dries out naturally, may take 2-3 days depending on where you live for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
washed bike now blowing main fuses
http://www.stromtrooper.com/dl650a-2012/89929-blown-main-fuse-after-wash.html
Main fuse blowing after washing bike
KYMCO ZING 125 Manual
Jul 27, 2016 | Kymco Motorcycles
Why is the ignition fuse keeps blowing and blowing main fuse
It's called a direct short to ground. Whatever is on those fuses needs to be checked. Main fuse, is it blowing when you turn on key or when you hook battery? If with switch then trace hot wires from switch. Blown fuses are from overheating, which is what a short does.
Oct 11, 2014 | Motorcycles
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Blowing ECM-B fuses
The first thing you should do is to locate the oil pressure switch/sending unit.
This switch serves two functions.
1) provide oil pressure reading
2) disable the fuel pump relay in event of oil pressure loss.
When this switch is failing to provide the correct pressure to the ECU. The wiring harness can overheat and eventually create a short.
ECM B blow is because the harness is grounding/shorting.
DO NOT drive the truck until you change the oil pressure switch.
After you change the switch,you should spend sometime to inspect the wiring between the fuel pump relay,ECU and fuel pump.
Please post up day on the comment window/page.
I will follow up on it later.
Good luck.
Aug 24, 2008 | 2000 GMC Savana
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Honda Maxus Prosumer MX5223 Pressure Washer Logo
37 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
