Question about Vornado Dryers
Electric motor wiring diagram
Power switch
  • 115 Answers
SOURCE: need electrical diagram for power windows motor
ck for power in the up and down positions at motor... one wire will lite up and the other wire will down... if no power up try looking at the wires in the door jam there covered by a rubber boot... if power to motor in both directions then its the motor
Posted on Aug 01, 2009
  • 308 Answers
SOURCE: wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Posted on Apr 01, 2010
Testimonial: "Thankyou for your assistance,very helpful."
bobicehouse
  • 1524 Answers
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
Posted on May 12, 2010
  • 5 Answers
SOURCE: I have made electrical connention wrong -only
send me your unit..
Posted on May 25, 2010
chestergth
  • 22 Answers
SOURCE: need wiring diagram for electrical household
A circuit its wired to feed switches, plugs or outlets, neutral, ground and hot wires, the rest like switches could be near the main power(brakers), in the middle or at the end, but they are like brenches from the main circuit, try to understand how electricity works and always try to be safe, if you dont know ask an expert or buy a manual, good luck ;)
Posted on Oct 04, 2012
I HAVE A 2000 OLDSMOBILE SILHOUETTE. MY REAR WIND SHIELD WIPER STOPPED WORKING. HOW CAN I FIX IT
First you must pull off the trim panel and expose the mortar and wiring to the motor, then test for power and ground, if present test the motor.
Aug 29, 2017 | Oldsmobile Cars & Trucks
2005 ford 150 . wipers don't work but washer still does work . could it be a fuse or wiper motor. or what? Ted H ope you can help thanks
Do you know how to test automotive electrical circuits ! Using a wiring diagram and a volt meter ? test power to the wiper motor .
Control from the switch .
http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter vehicle info. year , make , model an engine size . Under system click body & accessories , subsystem click wiper / washer . click the search button then the blue link . Look at the diagram for pin # 's an wire colors , see fuse at top of diagram . Check B+ power with volt meter . Check the inputs from the wiper switch to the motor . If all the power an inputs are good , replace the wiper motor .
Jun 12, 2017 | Ford Cars & Trucks
My passenger electric window is not working
Yes , test the electrical circuit ! Find a wiring diagram at http://www.bbbind.com/free_tsb.html free wiring diagrams . Do you have DVOM - digital volt ohm meter ? Do you know how to test volts ? Check for power at the passenger window switch . Go on you tube an watch a few different trouble shooting videos . How To Diagnose your Power Window Problem Is the Switch or motor bad Then test the circuit . Hope this helps you out .
May 18, 2016 | 2005 Kia Sedona
Note rear wiper stopped working any ideas?
Yes ,go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Check the electrical circuit (power & grounds) .Go to youtube check out videos on basic electrical trouble shooting , how to read a wiring diagram etc... Eliminate what's right till you find what's wrong . Fuse's ,relay's ,wiring , motor , switch , linkage etc..
May 10, 2016 | Cars & Trucks
Why Can't operate driver window?
The window switch could be bad or the window motor or the window regulator . The same could be wrong with the roof ,switch ,motor no power . Did you go on youtube ,could have videos on how to test ! Check out some basic electrical trouble shooting videos , how to read a wiring diagram too ! Go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Check the diagrams to see what powers everything , see what all is involved in the circuit , fuse's , relay's switches , motors etc... Buy yourself a digital volt ohm meter an test the circuit .
Apr 17, 2016 | Cars & Trucks
2005 kia sedona drivers side window does not work replaced motor and switch still nothing . someone please help me
Do you know how to do electrical troubling shooting > Do you know how to read a wiring diagram , do you own a DVOM - digital volt ohm meter , do you know how to use a DVOM ? Go on you tube an check out some videos on automotive basic electrical trouble shooting , how to read a wiring diagram . Also check out video on power window trouble shooting .Then go here for a free wiring diagram . http://www.bbbind.com/free_tsb.html We test not guess .
Mar 12, 2016 | 2005 Kia Sedona
Color coded wiring diagram 1995 gmc sierra electric windows
Google the
wiring diagram 1995 gmc sierra electric windows I found several systems offering what you require.
But what is the problem, 99% of the time in that year the window regulator was at fault, it was made from a stapped steel housing verses an cast unit. We check the left switch for power, disconnect the two wire connector at the motor, and see if the motor has power to one side or the other in the connector. If the switch has power to it, and the motor has power to it as you press the button, the motor is at fault.
Good luck.
Mar 16, 2015 | GMC Cars & Trucks
How to rewire a GE 75423 electric fan
Four wires coming from base to motor. I need a diagram of which wires connect to the electrical components in the base.
Aug 26, 2012 | Dryers
Electrical wiring manual or diagram on isuzu giga power window switch
i encountered this problem already check if the fuse is okay..remove the panel get a tester to see if there's a power supplying the motor. if none check the wires near the door hinges that's the place where the wires got pressed and prone to breaking. other thing is check for corroded switches
Nov 13, 2011 | Cars & Trucks
Need electrical diagram for power windows motor . my power window drivers side went down but will not go up? I switch thr switch and it is not the switc. I think it is the motor.HELP!!!!!!!!!!!!!!!
Jul 31, 2009 | 1991 Ford F150
Dryers Logo
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Mack Baxter
Bill Boyd
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
