Question about DeLonghi EC155 Espresso Machine
Ec155 delonghi ec155 water is cold not heating up
    New Friend:
    Problem Solver:
  • 7 Answers
If you have an ohmmeter, disconnect the cables that feed the resistance and connects the ends of the meter should give a value of element 5 to 30 ohm, if you give infinite that is very high due replacement it, there are also two thermostats one limit and a control, if you use this meter their connections resistance removing the cables connecting them, the measurement should be 0, if it gives you another value or infinite must change.
Posted on Apr 17, 2016
3 Suggested Answers
SOURCE: Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Posted on Mar 23, 2010
espressonist
  • 1711 Answers
SOURCE: I have a 6 moth old Delonghi EC155 espresso maker.
The problem is that the steam thermostat is not working right and leave the boiler overheat enough to start burning the boiler pastic seal and also the overheated steam blow out some boiler dirt gather by previus use which was liying in the boiler and it was gather from water, soil is brown color.
So now if you are lucky first dont switch it on again since it might be on the starting of the problem and you can avoid it by just replacing the steam themostat. Howevr you must work it then without the top cover with extra safety of course in order to visual check if you have any other damage from the overheating like gasket burned out and or water leaking or else.
Good luck
Posted on Aug 21, 2010
I have ran hot vinegar water through, it sounds like it is laboring to "bring the water up" is the sound.. it takes a long time & it seems not enough pressure to force water through the coffee.
Could be several things.
  • In the bottom of the water tank is a spring loaded "valve" that may be stuck shut. It is much more common for it to be stuck open.
  • There is a filter in the suction line to the pump. There is a chance that the hot vinegar loosened something that is now plugging the filter.
  • The hot vinegar may have damaged the pump. Cold vinegar may have been a better cleaning fluid. (A cold citric acid solution seems to be popular too now days.)
  • If the relief valve was lifted (opened) during this procedure, it is possible that it is not seating tightly.
If this was my machine, I would replace the filter and pump because they are the most likely items to be a problem. It is not a hard job but one does have to be patient and careful. I would take a picture every time I removed something just to be sure I got it back together right.
I've included a link to a part supplier part diagram. You can see the pump and filter.
Good luck. DeLonghi EC155 Cappuccino Maker Parts
May 30, 2015 | DeLonghi EC155 Espresso Machine
Tip
DeLonghi EC155 Doesn't Release Water
When I bought my EC155, I heated it up for 30 minutes and tried multiple times to run water through. After multiple attempts the water level remained unchanged. <br /> I was able to fix the problem by opening the bottom of the machine (4 star screws). After opening the bottom, I immediately noticed that one of the plastic pipes was not in the channel in which it was supposed to be and as a result was kinked and sealed off. I simply pushed it into the channel and that fixed the problem.
on Sep 14, 2011 | DeLonghi EC155 Espresso Machine
Coffee stops flowing
Run a 50/ 50 vinegar & distilled water solution through it. Only use distilled or bottled, purified drinking water from now on.
Feb 17, 2013 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
I NEED A MANUAL SO I KNOW HOW TO USE MY dElongi Espresso EC155
You can download the user manual directly from Delonghi from this link
Sep 28, 2009 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Problems with handle alignment
I had to use some olive oil around the outside of the filter cup holder to get it to move all the way to the right. After the first couple of times I was able to get it on straight without any oil...
Mar 15, 2008 | DeLonghi EC155 Espresso Machine
DeLonghi EC155 Espresso Machine Logo
236 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
