Question about Yamaha Grizzly 24-Volt Battery-Powered Ride-On, Camo
Squealing noise when driving
Squeals off & on when driving straight and turning
  • Pat Massey Vanecek
    Pat Massey Vanecek Feb 11, 2014
    I called Motion Trendz and they just told me to return the vehicle:(
Power steering squeal
You should not turn power steering to extreme locks and hold them there constantly. The squealing is the noise the power steering unit is screaming," You are killing me".
Mar 27, 2014 | 2005 Nissan Maxima
Squealing noise while driving and difficulty turning
rpm need to adjust and check atf oil level and couler
Jan 20, 2014 | 2002 Chevrolet Malibu
Squealing sound when air conditioning is on and turning left
same problem...not an a/c issue. When the fan is on and when you turn left.sounds like something rubbing in the blower. took the blower off, no obvious blockage.
Apr 19, 2012 | 2003 Pontiac Vibe
Car is squealing persistently from rear right tire
Pull the wheel,you will find that the brake pad,or after pulling the drum,the shoes are in bad shpe,if not ,check the wheel bearing,but my bet is the shoes,or pads are bad,do A brake job,it will most likely be the problem.
Sep 25, 2009 | 1991 Honda Accord
Funny noise/squeal from LH wheel area on turning RH bends
Check your brakes for excessive wear or uneven wear. There are metal objects attached to the brake pads, that when worn they touch the rotors creating a metal squealing sound. This serves as a warning to prevent additional damage to your braking system, replace if pads are worn. If this isn't the case, if 4WD have your shafts, hubs bearings checked, if 2WD have your wheel bearings checked. Hopefully this helps
Jul 28, 2009 | 2006 Nissan Pathfinder
I have an 05 freestar that squeals going straight its not belts pilleys or brakes
what about the wheel bearings they wont squeal going around a corner because the weight on them but they will while driving straight.
Jun 10, 2009 | 2005 Ford Freestar
Squealing noise
sounds like a belt or a pull that the belt rides on . you should spray belt dressing on the belt and see if it stops squealing . you can it at you local parts store
Jun 03, 2009 | 2005 Ford Freestar
Loud squealing noise
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
Dec 13, 2008 | 2003 Nissan Pathfinder
Squealing noise
sounds like a loose belt!!
Yamaha Grizzly 24-Volt Battery-Powered Ride-On, Camo Logo
44 people viewed this question
Top Yamaha Toys Experts
ray gallant
Are you a Yamaha Toy Expert? Answer questions, earn points and help others
