Question about Thermador Professional PODC302J 30" Double Electric Wall Oven with 4.7 cu. ft. True Convection Ovens, Self-Clean, 14 Cooking Modes, Rotisserie, Temperature Probe and 3 Telescopic Racks
My electrician need tos know how to wire this unit.
What size circuit breaker is needed for a jenn-air wall oven 240 volt 3 wire #6wire model 800181
most ovens require a 30 amp circuit breaker ( now RCD unit)
talk with an electrician as to the requirement
Aug 17, 2016 | Jenn-Air Ovens
Our GE JKP14 Oven's Burner Element caught on fire. A small bit of it. Turning the oven off did nothing, but once we turned off the circuit breaker the fire instantly went out.
call in an electrician as turning off the switch should have stopped the fire
There may be a problem in the way it is wired up.
Apr 07, 2015 | GE Ovens
Hi i have purchased a milano 60cm fan forced wall oven. the electrician putting in a new circuit needs to know how many amps 15A or 20A.. Thanks Tony
Sorry but if he is an electrician he should know what to do! The new wall oven will have a sticker on it with the kilowatt rating. The kilowatt rating is used to calculate the current it will draw. This calculation is dependant on your voltage supply. Once this is worked out it will determine circuit size. If your electrician can't work this out you need to find a new electrician.
Mar 01, 2011 | Ovens
Hi , i am an electrician installing a westinghouse pek1380w-r stove , my mate that bought the stove is still waiting for the manual and cannot tell me how many amps the stove will draw so i can select a...
this unit will draw up to 50 amps if all burners are operating. i do not know the exact wattage, but they usually have an 8 gauge wiring connector already on the oven, if a wall oven.
if a free standing then you will have to put on a cord that will also be an 8 gauge.
you will need to determine what wire gauge to use depending on how long of a run you have from the circuit panel to carry the load.
it is also a single phase 240 volt system, but that doesnt matter because the wires are the same.
are you new at being an electrician? check your code book to make sure you are doing this wiring by the codes for your area.
Jan 12, 2010 | Ovens
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Dec 01, 2009 | Maytag CWE5800A Electric Double Oven
1 or 2 circuits to create 2 phase?
How to explain this? your new drop in unit will require a 220v circuit capable of a specified amount of amps. Typically 40, 50 or 60. Should be noted in the manual and on the unit itself. If your original oven and cooktop were electric, then each one was probably hooked up to a 220v circuit. The problem is figuring out how many amps were supplied for each. The simplest way is the go to the panel and find the breaker for the old oven and cooktop and read the numbers (or amps) on the on/off switch. If either breaker has a number the same or greater then the drop in unit says it requires, then your all set. If the drop in unit says it requires 52amps and one of the breakers says 60 on it, your fine. If the drop in unit says it requires 44amps and the breakers are 30 or 40, then you got a problem. Usually a breaker is installed that is the maximum amps allowed for the size (thickness) of the wire connected to it. You CANNOT connected a 50a breaker to wire only rated for 40a. Note the size difference of wire connected to a 20a breaker with wire connected to 40a breaker. If the drop in unit requires more amps then the original units used, then a larger wire will need to be ran from the panel to the drop in unit (Not cheap). Now if the original oven used a 30a and the original cooktop used a 30a, then its possible ( 80% of electricians wouldn't do it because of liability problems) to use both wires together to create 60amps, but both wires (actually a total of 6 wires, 2-120v wires and 1 ground wire from each outlet) would need to be in the same outlet box for the drop in unit connection.. I could (and probably should) try to explain more, but I'de probably just confuse you more. GOOD LUCK!
Nov 28, 2009 | GE Profile JT952 Electric Double Oven
I'm replacing an old electric range with a new one. The old wiring is a black, white,and green, 3 wires. The new electric range calls for black, white, red,and green, 4 wires. How do I set it up and get it...
Outstanding question, ask the guys:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
I want to know myself.
Sep 13, 2009 | Tappan 30IN ELEC IGNa Oven
Wiring oven microwave wall unit
sounds as if you need an electrician, the red is a "hot" lead and if not at the wall id say you have the wrong power supply at location
Nov 29, 2008 | Ovens
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Thermador Professional PODC302J 30" Double Electric Wall Oven with 4.7 cu. ft. True Convection Ovens, Self-Clean, 14 Cooking Modes, Rotisserie, Temperature Probe and 3 Telescopic Racks Logo
114 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
