Question about eMachines El1352g-41w Pc Desktop Pc Mini Tower
Bios emachine - eMachines El1352g-41w Pc Desktop Pc Mini Tower
    Brigadier General:
  • eMachines Master
  • 3,400 Answers
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
I have four sata ports inside my emachine desktop and my bios says not installed
If the SATA ports are showing not installed on the BIOS then it can be due to either older BIOS version or the Ports are not detected. I recommend to update the BIOS from the emachines website, please follow the link below:
htttp:\\support.emachines.com
Select the computer model and download the BIOS
It should take care of the issue.
Thanks and regards,
Jitha.G.J
Dec 20, 2011 | E-Machines eMachines Desktop PC
Wont start emachine 4260
FIRST OF ALL NEVER GO INTO BIOS UNLESS YOU KNOW WHAT YOU ARE DOING!SET YOUR BIOS TO DEFAULT SETTINGS,I HOPE YOU DID NOT TRY TO OVER CLOCK YOUR COMPUTER.SO MY ADVICE IS TO TAKE IT TO YOU LOCAL COMPUTER REPAIR SHOP AND TELL THEM YOUR PROBLEM AND THAT YOU WENT INTO BIOS.HOPE THIS HELPS BYE
Nov 27, 2009 | E-Machines eMachines Refurbished EMA...
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
eMachines El1352g-41w Pc Desktop Pc Mini Tower Logo
44 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
