Question about Tablets & eReaders
My trio stealth tablet wont turn on unless its plugged in. but as soon as I un plug it it dies. it also says it 100% charged. anyone know why?
agc93
  • 44 Answers
SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Hope this helps, Alistair
Posted on Mar 15, 2011
SOURCE: My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
Posted on May 16, 2012
SOURCE: Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Posted on Jun 27, 2012
  • 34193 Answers
SOURCE: charger gets hot while plugged in and does not charge tablet. tablewt is dead wont turn on.
The battery may be unable to charge
Posted on Sep 29, 2012
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Posted on Feb 20, 2013
Tablet turns on and then shuts down right away
Your tablet is not charging , those are the symptoms of an empty battery
Mar 17, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
Tablet wont turn on
I was experiencing the same exact issue recently. I had to do a hard reset on my tablet. I was scared at first because I was told by some that I would lose all my apps, videos, music, photos, etc. Then others told me I would not lose anything. I did a hard reset and everything was restored.....nothing lost.
Mar 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Tablets & eReaders Logo
18 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
