Question about Hitachi 60SDX88B 60" Rear Projection Television
60SDX88B burned out resistor #220 will no longer function.
This problem occurred all at once when the television made a pop sound and all of a sudden went black. A smell of smoke followed which I actually noticed was a resistor #220 smoking away. This was on the board on the bottom right most. As resistors aren't usually prone to failure I would assume a capacitor has probably gone upstream. Does anybody know which component I should be looking at replacing? I have photos but Im not sure how to upload them here.
  • Drake Conrad
    Drake Conrad Feb 09, 2014
    I found the photo upload button. Here's a visual update of the problem.
  • Drake Conrad
    Drake Conrad Feb 11, 2014
    Here's a close-up of it
premtech
  • 934 Answers
SOURCE: convergence problem
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Posted on Jun 01, 2007
TVtechmaniac
  • 140 Answers
SOURCE: Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Posted on Aug 20, 2007
Slinteriors
  • 8617 Answers
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 1.5 ohm resistor rk 46 keeps blowing
You should have put the original OEM STK's in the set - if your set had 110's or 120s put those chips only. Do not risk different chips with different specs/amps/ etc....when you do resistors blow as you have discovered.
Posted on Mar 15, 2009
  • 87 Answers
SOURCE: Incorrect resistors on DP1X PWB?
If your tv is a 43uwx10b the original values of the resister are correct it is a DP14G chassis do not change the values
Posted on Apr 15, 2009
My sound system had a smell of burning from the main unit and suddenly stopped working. I switched it off and now although all the function lights are on there is no sound from the system but no longer a...
radios often have components that over heat and burn out. Once burned out they have to be repaired or replaced. Ford F150 trucks are notorious for that.
Mar 02, 2015 | Cars & Trucks
Burn r704 resistor in my sharp tv 21v-fr70m,, i want to know the value,,, help poh mga master...
leo_arsolaci.jpgleo_arsolaci,
sir here is the exact value of resistor r704-220 ohms and please check also the zener diode 8.2 volts....
Sep 30, 2011 | Televison & Video
Has a convergence problems is it neccesary to replace the 220 resistors, and the 5% Not sure of value.
you must go in yhe meny and set convergens point to point...or use the auto function.....try to reset to factory first.....NOT REPLASE 220 RESISTOR..
Aug 18, 2010 | Toshiba 43H72 43" Rear Projection...
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 60SDX88B - serial V9C005014 - Rear projector IC's problem
The most commond problem is Q777. Check that transistor and check Q657 and EP98 also. This should take care of the problem.
Jan 25, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Blank screen,power led on, fans running
Do you have a DLP or Plasma set????? Give me the model #.
Apr 01, 2008 | Hitachi 60SDX88B 60" Rear Projection...
RCA D56W20 no power
Opps! Your problem is most likely in the power supply section. No doubt a blown fuse, a diode or two and probably a few resistors. To be sure that you found all the problems you will need to check all the components in the power supply. If you know how to use a DMM have at it, safely of course. First unplug it, if you already haven't done so. Check the fuse for continuity. If you are lucky that may be your only problem, but don't count on it. Look for burned components or burn marks on the circuit board. Don't overlook resistors with large values and replace any components which do not test within the proper parameters. When you are sure that you found all the problems don't plug the unit back in to 220 or you will have to do it all again. Get the appropriate sized 220/120 transformer which means one with a current rating higher than the current draw of the TV. That information should be on the data tag on the rear of the unit. Again, remember safety and Good luck.
Jun 29, 2006 | RCA D56W20 56" Rear Projection Television
Hitachi 60SDX88B 60" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
